Removing SMOG equipment?
Old Mar 13, 2007 | 06:45 PM
Phire13's Avatar
Phire13
Default Removing SMOG equipment?
Question? I have un-wanted / Un-needed smog equipment on my engine, are there any ill side effects of removing said equipment without pluging holes in exhaust manifold, besides sound from exhaust? Or any other parts of engine, or tuning?
Old Mar 13, 2007 | 07:50 PM
7T1vette's Avatar
7T1vette
You really don't want exhaust fumes in the engine compartment, as they will work their way into the cabin air vent system and kill occupant brain cells. Can you pass your state inspection requirements without the pump system? Can you sell it to someone else without it? If you still want it off, pull it...but keep the components for later use [or resale]. I would think you could tap the holes for set screws (installed with anti-seize compound) or even fill them with JBWeld metal/epoxy.
Old Mar 13, 2007 | 08:05 PM
Phire13's Avatar
Phire13
I don't need to pass smog tests its a '74 and doesn't have cats either, not planning on selling the car, and really don't want to keep the smog stuff. Still learning about vettes and engines, so thats why I ask, Is JBWeld easy to use?
Old Mar 13, 2007 | 08:32 PM
77BuffaloVet's Avatar
77BuffaloVet
Get some muffler tape or an exhaust pipe patch kit and cover the hole...
Old Mar 13, 2007 | 08:39 PM
694speed350's Avatar
694speed350
Don't know about your car but my '69 had 4 ho;es on each exhaust manifold. you can plug them with brass brass plugs. thats the way my car is.
Old Mar 13, 2007 | 08:47 PM
SIXFOOTER's Avatar
SIXFOOTER
Jesus, your going to need a fire extinguisher a lot sooner than worry about some drunk brain cells
1. Take out the pump and its associated plumbing and plug the manifold holes, OR, Bubba would put a plug on the check valve
2. Take it to the car wash with a latge bottle of Simple Green and clean everything under the hood.
3. Paint the crappy looking compressor, valve covers, Intake etc..
4. clean the overspray off the overflow bottle
Old Mar 13, 2007 | 08:51 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Your engine was designed to run with all the smog equipment, so its tuned to run with it. If you just start pulling hoses and capping all the equipment, I would not be surprised if you experience any problems. When I bought my '75, all the smog equipment was disconnected. Maybe it was subconcious, but I felt the car ran better when I reattached it all properly, especially in terms of gas mileage.
Someone with way more knowledge will give you good details, but I'll tell you I'm nixing the entire set up and going with a rebuild.
Old Mar 13, 2007 | 11:38 PM
palamesa's Avatar
palamesa
Removing the smog equipment will do very little, if anything to improve your performance. The mid 70's 350 motors were all down on HP. I'd rebuild the motor with all the goodies (heads, cam, intake, carb, etc) or put a crate motor in it. At that point, the smog stuff can come off. I'd follow my own advise but I have a 76' model that still get CA inspected so I have to keep mine fairly stock. Take advantage of your exemption!
Also....clean that mess up under the hood while your at it....palamesa
Old Mar 13, 2007 | 11:51 PM
Big2Bird's Avatar
Big2Bird
Some Chevy manifolds came drilled and tapped with four holes with plugs already installed. 1 manifold for many applications. Not all cars had the AIR manifold. Someone will still have/make the plugs.
Old Mar 14, 2007 | 08:53 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
If you do remove the smog equip, do it carefully.
Then either store it or sell it on Ebay, that stuff is worth $$ to a restorer!
Old Mar 14, 2007 | 01:10 PM
Phire13's Avatar
Phire13
Thanks, I was thinking from reading around in the forum the JBweld stuff might be a good choice.
I just recently got the car and haven't had the time or place to give it a good scrubbing yet. But thanks for the Input.
Thanks, but I don't think that it will change too much as far as I can see it only has those couple of hoses to the exhaust mainfolds. As for the gas mileage I would not have bought a old muscle car if I was worried about gas mileage.
Will do, thanks.
Great! It would be nice to make some money off this car rather then dump money in, I will sell the equipment when I take it off, I will also sell the Steering wheel too, '78 25th anni wheel.
Old Mar 14, 2007 | 01:48 PM
3rd_Vette's Avatar
3rd_Vette
Since you live in Sacramento, own a 74, and want to rid yourself of the smog crap, you are in luck. Unless the Governator Arnold makes the 75 and older cars return to the bi-anual smog checks, you can do alot. Use the smog tubes and PLUG them. New non EGR Manifold and a few other things that the Kolofornia Smog natzis have required on your car and you will have a good runnung 350 with alot more power. You have so many options that the 76 and newer Vette owners don't have in Calif... ENJOY your Freedom!
To Removing SMOG equipment?
