WTF? Wheres the timing tab?
Old Mar 13, 2007 | 09:36 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
Default WTF? Wheres the timing tab?
I've had my 68 327/350 for about 2 months, it runs ok, but when you hit the loud pedal it stumbles, pops and pisses.
I've read the timing/carb sticky and started to go through the motions, but looking at the engine, I can't find the timing tab! It's been a while since I timed a SBC, I don't remember any tabs being on the bottom? I didn't get a chance to jack it up to look, but as best I as can see there isn't a tab on the engine. Is it missing? If so, what's the cure?
The previous owner said it's not the original engine, code stamped on the deck is F080HC. Can anyone interpret this?
Thanks in advance,
Bud
Old Mar 13, 2007 | 09:46 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Thanks in advance,
Bud
on a 350 if you look at the power steering pump and the harmonic balancer you should be able to see it sometimes the tabs break off....if you got to summit you can get new ones that attach by using the timing chain cover bolts to hold it in place, i'm not sure on a 327 where it is but i would start there
Old Mar 13, 2007 | 10:55 PM
DZRick's Avatar
DZRick
This is a 68 small block.
If you need a better picture let me know.
I'll dig out my books if nobody decodes your numbers soon.
Old Mar 14, 2007 | 07:50 AM
Poppa Bud's Avatar
Poppa Bud
I can't see the picture, just the red X box.
Old Mar 14, 2007 | 11:02 AM
DZRick's Avatar
DZRick
I can see it both in my post and your responce.
PM me your e-mail address and I'll send it to you.
One more try here just in case.
Old Mar 14, 2007 | 11:21 AM
Poppa Bud's Avatar
Poppa Bud
Thanks,
That one showed up, don't know why I couldn't see it before
So if I'm reading the pic correctly it's on the drivers side. I wonder if it's hidden by the power steering pump. Have to check after work.
Old Mar 14, 2007 | 07:38 PM
jlaw68's Avatar
jlaw68
if its like my 78 then its under the water pump. you have to look between the water pump and the timing chain cover to see it and if you have to wrong water pump on it you wont be able to see it at all.
To WTF? Wheres the timing tab?
