Roller cam with no button.
Old Mar 17, 2007 | 01:04 PM
Block_Head's Avatar
Block_Head
Default Roller cam with no button.
I bought a 350 motor that the builder had made into a roller rocker and roller cam motor. I was emailing back and forth with him about parts i needed to buy for this new motor and he informed me there was no cam button. He told me the roller cam would not walk and that the chain would keep it centered where it needed to be. This doesnt sound right and i need to know if im going to have to pull it all apart and put in a cam button. Will this turn into as problem since its an old motor that someone turned into a roller motor? He said something about a step nose roller cam and its in an old 350 block.
Old Mar 17, 2007 | 02:41 PM
Block_Head's Avatar
Block_Head
Ive done some calling and i cant find a cam buttom kit for a newer roller cam thats in an old engine. Please help.
Old Mar 17, 2007 | 03:36 PM
Belgian1979vette's Avatar
Belgian1979vette
I asked about cam buttons a week or so ago.
A roller cam needs a button, because the cams do not have a tapper and the action of the oil pump makes it walk to the front of the block. Maybe the chain would prevent it from coming out to far, but it all depends on the strength and tension of the frame.
The cam button mounts in the center hole of the timing sprocket. It prevents walk by thouching the timing chain cover.
The discussion I started was about the way the end play was to be controlled on the button. I had my timing cover dented and then adjusted so there was no play, but I have a rollerized button. There seemed to be no agreement on which was to be the right method. I will probably take of the oil pan and timing cover and redo things.
Yves
Old Mar 17, 2007 | 03:42 PM
Block_Head's Avatar
Block_Head
Yves
Thanks. I would do the same thing but i cannot find one that will work with this combination of old engine and new cam. It looks like the step nose cams need a specific cam button retainer that wont fit or bolt to an older block.
Old Mar 17, 2007 | 03:57 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think this has been covered here before. Try an archive search.
Old Mar 17, 2007 | 04:17 PM
Block_Head's Avatar
Block_Head
Thank you, im batman, i did try using the advanced search but again my problem is that this engine has a cam that needs a certain kind of retainer for the button and im told that that kind of retainer wont fit or bolt to the block its in.
By the way im batman i have seen a lot of your posts and really like having guys like you here for when i need help.
Old Mar 17, 2007 | 04:30 PM
Gordonm's Avatar
Gordonm
The other thing is you will need a cover that is reinforced or a different one than stock. The stock steel cover will flex under load from the cam allowing it to walk slightly. You do not want this. A reinforced stock cover or an aftermarket cover will work.
Some water pumps also have a threaded hole that you can put in a stud or bolt that is in the location of the cam button so this reinforces the cover.
Old Mar 17, 2007 | 04:37 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
The Cloyes cover has an integrated cam button I think will work with this application.
Old Mar 17, 2007 | 04:57 PM
Block_Head's Avatar
Block_Head
Sounds perfect. Do you have a part number or a full name of the cover i can use to search?
Old Mar 17, 2007 | 05:08 PM
63mako's Avatar
63mako
CLOYES #9-221
Old Mar 17, 2007 | 05:13 PM
Block_Head's Avatar
Block_Head
CLOYES #9-221
Thanks i think i found one on ebay and i see that autozone and oreilly can order it for me.
Old Mar 17, 2007 | 05:17 PM
63mako's Avatar
63mako
Check first and make sure it works with the late model cam. It will also clear the short water pump with a touch of the grinding wheel on a couple of the bolts.
Old Mar 17, 2007 | 06:06 PM
Block_Head's Avatar
Block_Head
The guy selling it calls it a late model cloyes cover but cant say if its for late model roller cams.
Old Mar 17, 2007 | 07:12 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You need access to back of the cam to set endplay properly. The only way I know of to set it without a dial indicator on the back of the cam is to get a timing cover I have found recently from BLP products which has a hole in the cover for the dial indicator. I would imagine this cover is fairly expensive.
So if you can't access the back of the cam then you are going to have to guess what .006-.008" feels like when you rock the cam back and forth with a screwdriver through the lifter bore, sounds like fun ?
Old Mar 17, 2007 | 07:32 PM
63mako's Avatar
63mako
The Cloyes cover is setup to adjust the button from the outside with the cover in place. The directions say to snug it till you just make contact with the cam. The greater expansion rate of the aluminum allows for proper endplay. Just read the sheet.
Old Mar 17, 2007 | 07:38 PM
MotorHead's Avatar
MotorHead
I have had two Cloyes timing covers, I set the endplay with a dial indicatior This must be somethng new, probably put in because people were asking what use this timing cover was if they had to remove the motor to use it properly
Old Mar 17, 2007 | 07:47 PM
63mako's Avatar
63mako
Could be. Looked pretty slick to me. Just bought one.
To Roller cam with no button.
Old Mar 17, 2007 | 07:56 PM
MotorHead's Avatar
MotorHead
I have to tell you that would make things much easier if all you had to do was to snug it up. I really would have to research that a little more though before I went ahead and did that. There was no mention of this method in my instructions on my previous 2 purchases of the Cloyes cover.
Old Mar 17, 2007 | 07:59 PM
63mako's Avatar
63mako
Will Do! I'm all about research. EDIT:Cloyes Quick Button Two-Piece Timing CoversEasy access to your cam.
These Cloyes Quick Button two-piece timing covers have a removable center plate with an O-ring seal to allow easy access to your cam when changing timing or the cam itself. Depending upon your application, some covers feature a built-in roller cam button that allows you to adjust cam endplay with the cover in place. Precision-machined from die-cast aluminum for sure sealing, these covers fit with most water pumps and timing sets.
Old Mar 17, 2007 | 11:30 PM
63mako's Avatar
63mako
Here is an informative article about the importance of proper endplay: http://www.chevyhiperformance.com/te...r_cam_endplay/
