Roller cam with no button.
Old Mar 18, 2007 | 02:03 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by Block_Head
Thank you, im batman, i did try using the advanced search but again my problem is that this engine has a cam that needs a certain kind of retainer for the button and im told that that kind of retainer wont fit or bolt to the block its in.
By the way im batman i have seen a lot of your posts and really like having guys like you here for when i need help.
We all like to be helpful. I could have sworn someone asked the same question a few months back, but I may be wrong. I hope you get it figured out.
Old Mar 18, 2007 | 08:40 AM
Fevre's Avatar
Fevre
Here is the thread http://forums.corvetteforum.com/show....php?t=1642104
Old Mar 18, 2007 | 09:33 AM
redvetracr's Avatar
redvetracr
Originally Posted by I'm Batman
I think this has been covered here before. Try an archive search.
or the engine mod section.....
Old Mar 18, 2007 | 10:42 AM
Belgian1979vette's Avatar
Belgian1979vette
I have some additional question regarding the cam button. If you use the comp cams 2 piece timing chain cover :
- will this cover clear the corvette water pump ?
- the rollorized crane button was installed taller than my stock chain cover, will it also be taller than the comp. cams cover ? If so, what can be done.
- if the button is smaller, it will probably need shimming. What kind of shims to use ? Can these be had with summit (i buy all my motor parts via summit)
Old Mar 18, 2007 | 11:28 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Yes. Might have to touch a couple of the rear pump cover bolts with a grinder
Sell your crane button. This cover comes with the button made into the cover.
if the button is smaller, it will probably need shimming. What kind of shims to use ? Can these be had with summit.
No shims required. The adjustable button is integrated into the cover. The covers are available through Summit.
Old Mar 18, 2007 | 03:09 PM
Belgian1979vette
thanks 63Mako
