Brake lines coming loose?!
Old Mar 17, 2007 | 06:58 PM
1mollyd's Avatar
1mollyd
Default Brake lines coming loose?!
A few months ago I replaced the brake lines on my '69 with all new stainless steel lines.
I installed all the lines, tightened them and then pressure tested the entire system. I retightened any small leaks and then filled the system with brake fluid and bled the system.
I'm now getting ready to get the car on the road this spring and I notice that the rear compartment of the MC is losing fluid. I trace it out and I find that the 2 trailing arm lines are leaking, very slightly, where they connect to the calipers.
I retighten the lines and refill the MC, then a couple of days later the same thing is happening! So I retighten them again and refil, then a few days later, same thing!
Could this be a problem with the new lines or with the calipers? Or is this normal with stainless lines?
Any one have a similar experience?
TIA
Dave
Old Mar 17, 2007 | 07:02 PM
Durango_Boy's Avatar
Durango_Boy
Probably cheap fittings.
Have you tried a form or Locktite?
Old Mar 17, 2007 | 07:05 PM
redvetracr's Avatar
redvetracr
loctite?? on a brake line??
...redvetracr
Old Mar 17, 2007 | 07:08 PM
noonie's Avatar
noonie
Stripped threads on fittings?
Old Mar 17, 2007 | 07:09 PM
Durango_Boy
...redvetracr
My question was to determine if a substance other than brake fluid on the threads may have been hindering their hold in the caliper.
Old Mar 17, 2007 | 07:10 PM
1mollyd's Avatar
1mollyd
I was always told not to use anything one brake lines because the flare fitting is supposed to provide the seal, not the threads.
No?
Old Mar 17, 2007 | 07:12 PM
Durango_Boy
No?
You were correct.
New fittings, and re-flaring the lines might be a better idea than replacing the calipers.
Old Mar 17, 2007 | 07:32 PM
1mollyd's Avatar
1mollyd
You were correct.
Thanks, I may have to try that.
The lines and fittings are all new, so I was suspicious of the calipers.
Dave
Old Mar 17, 2007 | 10:10 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
some times you need to reseat the SS fitting several times since they are so hard, i would try this at least. perhaps they are not tightening down all the way and you are getting a false impression that they are seating .....i would alternate between tightening and loosening them and see if they snug up better
Old Mar 17, 2007 | 11:03 PM
Artsvette73's Avatar
Artsvette73
To Brake lines coming loose?!
