Rustproofing Inside Frame Rails
Old Mar 19, 2007 | 06:32 PM
stinger12's Avatar
stinger12
When I said to properly apply this stuff, I was referring to properly applying this stuff to the inner frame rails, where there is limited access.
Old Mar 19, 2007 | 08:14 PM
MN80Vette's Avatar
MN80Vette
Originally Posted by 74L82Cpe
After my research, I bought a "rustproofing and undercoating" felxible wand sprayer kit for frames and body cavities from Eastwood for about $50. I may use the rag trick too. I also bought their rust converter, rust encapsulator, frame paint and HD anit-rust prevention paint. The rust convertor is a two parter to kill the rust, the rust encapsulator is claimed by them to be better than POR15 (who knows?) and has built-in UV resistance , the frame paint is a top coat that provides chip resistance, and finally, they recommend using their HD anit-rust paint inside frame rails. (The first three items will mainly be used as a system on the outside of the frame.) Anti-rust (for inside the frame) is a paint that drys but stays somewhat soft and self repairing from scratches (they say). It cannot be painted over however so I guess it has some wax or something in it. My thought is that it might be preferable to chain saw oil (that I had considered) because anti-rust will dry and not attract and collect dirt and should not have to be reapplied for a long time because it will not wash off (needs a solvent to remove).
This all may be overkill, especially since my frame is in very good shape, but I am only planning to do this just once and a frame-off is (hopefully) NOT in my future. This is costing me north of $250 for everything from Eastwood. You could definitely save money going some other routes.
FWIW
The frame on my '80 is in pretty good shape - surface rust only, even in the kickpanel area. The car spent most of its like in Arizona and less than a year in California before importing here to Minnesota. I plan to buy the Eastwood undercoating gun, hoses, and bottle, and probably their products too. They just replaced their old spraying system (#160003) with a new one (20441), still for $50.
Old Mar 19, 2007 | 08:31 PM
corvette74's Avatar
corvette74
I used POR-15 on mine. I just picked up an undercoating gun with a flexable tube on the nozzle. I sprayed it rite from the can, but next time I would thin it a bit to get more even coverage.
Old Mar 19, 2007 | 09:06 PM
stinger12's Avatar
stinger12
corvette74, can you provide some more details to what steps you took to prepare the metal? Did you follow the three step process por-15 recommends...or was it too much to do the three step process? Please provide more detail.
Old Mar 19, 2007 | 11:14 PM
stinger12's Avatar
stinger12
bump
Old Mar 26, 2007 | 11:11 PM
randyward's Avatar
randyward
Hey Tommy,
Just wanted to connect with a Brit car guy-I have a '68 BB Conv't, as well as some real cars-67 Morgan, 73 XKE, 74 MGB, 76 TR6.
Cheers
Randy
Old Mar 27, 2007 | 08:00 PM
ShinodaVette's Avatar
ShinodaVette
I'm surprised more people don't use Eastwood's heavy duty anti-rust. It comes in quarts and is sprayed in. I used it and was happy with it; even though it was a messy job. My frame is powder coated and was chemical dipped prior to that.
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Old Mar 27, 2007 | 09:05 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Originally Posted by 72LS1Vette
POR is kind of dangerous to spray unless you have a really good respirator. It cures by absorbing moisture so imagine how fast it will harden inside your lungs.
Rick B.
I know somebody who ended up in the hospital for a week becuse of doing this with POR-15. This guy sprayed his frame without a respirator and the next day was in intensive care.
Old Mar 28, 2007 | 09:58 PM
Spot Rot's Avatar
Spot Rot
1. POR-15 is great for many things but spraying it can be very dangerous to your health.
2. Any undercoating that hardens will trap moisture and actually accelerate rusting where it eventually delaminates.
3. Coating the inside of the frame with oil one time will almost certainly prevent any of our C3 frames from rusting further where it counts.
4. There's a troublesome 'compartment' partially blocked off in the last inch or so of rear end of the main frame rail (in front of the rear tire) that traps dirt and debris which holds moisture and can thereby cause rust-through in otherwise excellent solid rust-free frames. That place deserves special attention, blowing it out and oiling it.
John
Old Mar 29, 2007 | 09:48 PM
ikwhite's Avatar
ikwhite
Default Homemade Waxoyl ?
While doing a search on the Waxoyl rust inhibitor that someone mentioned I came across this recipe to make your own, so thought I would post a link for the financially challenged DIY'ers to perhaps research some more and use if they find it is safe and might work for them.
http://www.geocities.com/wallaces_21/waxoyl.html
I am personally not sure how safe this is to make or use so please do your own research before attempting to fool with this recipe!
ikwhite
Old Mar 29, 2007 | 10:10 PM
shafrs3's Avatar
shafrs3
Originally Posted by saudivette
I've used fisholene (fish oil) before and that works well...
I can hear it now, "Hey Dude, that may be a Stingray but it smells like a tuna boat!"
Old Mar 29, 2007 | 10:58 PM
Smly1971's Avatar
Smly1971
What about linseed oil and kerosene mixed 50/50? I spray this under my cars before winter and it holds up well. I am thinking of this for my inside my frame.
