battery drainage (please help)
Old Mar 19, 2007 | 11:09 AM
dhoffman's Avatar
dhoffman
Default battery drainage (please help)
i have a 1978 vette and am looking for advice... i have a battery draining and have located the fuse that is doing it. when the "clk,ltr-ctsy" fuse is pulled the drain stops. i dont have a lighter, my clock doesnt and has never worked and i have pulled the bulbs on the courtesy lamps inside the car and the drain is still there. is there another place to look or am i missing something??? please help...
Old Mar 19, 2007 | 11:11 AM
Big2Bird's Avatar
Big2Bird
Does your courtesy light have a delay timer?
Old Mar 19, 2007 | 11:17 AM
dhoffman's Avatar
dhoffman
yes it does
Old Mar 19, 2007 | 11:19 AM
Big2Bird's Avatar
Big2Bird
Originally Posted by dhoffman
yes it does
Unplug it. See if it (drain) goes away.
Old Mar 19, 2007 | 11:23 AM
dhoffman's Avatar
dhoffman
not sure where its located or what it looks like
Old Mar 19, 2007 | 11:25 AM
Big2Bird's Avatar
Big2Bird
On an 81 it is behind the glove box, right side, orange item. Not sure of 78
Old Mar 19, 2007 | 11:27 AM
dhoffman's Avatar
dhoffman
orange box an inch or so in size, i just seen that on the driver side near the fuse box, i will go unhook and try that and see what happens, i will let you know thanks
Old Mar 19, 2007 | 11:38 AM
dhoffman's Avatar
dhoffman
i disconnected the delay timer and now when i put my test light across the neg. terminal the light is bright for a split second and then a flickering red like it doesnt have much power going across it, is this normal. when i have the fuse pulled the test light illuminates just a bit less. also do i need to replace the delay or will my lights work without it for the time being??
Old Mar 19, 2007 | 04:02 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I am quite convinced by knwoing a lot of C3 owners that these babies will drain off about every month. I have tried to figure out why and haven't had much success. I put in a battery switch and if I am not driving regularly, I just disconnect the battery.
Old Mar 19, 2007 | 05:29 PM
dhoffman's Avatar
dhoffman
i took it out and spliced the two white wires together and no it works like a normal car without the delay. once less thing to worry about now, thanks
Old Mar 19, 2007 | 09:00 PM
Big2Bird's Avatar
Big2Bird
Old Mar 20, 2007 | 12:25 AM
GettnBetter's Avatar
GettnBetter
I had a similar problem for years on my 81, destroyed more than a few alternators recharging the battery actually. Even my auto-parts store told me "we can no longer replace these things for free even though they have a lifetime warranty".
It ended up being a stoopid dinger. The thing that made the ding or clicking sound (I actually never heard it) got stuck and just drained continuously. I removed it (large black thing on the fuse panel) and it corrected the problem.
Not sure if a 78 has one.
Old Mar 20, 2007 | 06:22 AM
guppie's Avatar
guppie
St. Jude Donor '08
78's are located behind the glovebox, remove it and this is what it looks like. I bypassed mine so my courtesy lights still work. I also put in a battery kill switch because I could never eliminate the drain completely, my clocked work fine. After about a week or so my battery would be down. since the kill switch install no problems even after the winter months went by
To battery drainage (please help)
