carb settings? please help..
Base setting for the idle mixture screws is 4 turns out from lightly seated. But this needs to be adjusted and set up for the car/engine combo. Acceptable range is between 2 to 6 turns.
A base 77 auto trans Vette will have trouble spinning the tires out from a standing start on dry pavement with the stock rear gears.
If you're going to add headers, you will need to re-jet that carb.
Contact me if you need the carb set up right:
V8FastCars@msn.com
Lars
http://www.centuryperformance.com/vacuum.asp
First make sure that your timing is correct. See sticky at the top by Barry K.
Oh, BTW, I would take Lars up on his offer to help with sorting out your carb problems...he knows what he is talking about.
Carb 1:
Incorrect primary jets
Incorrect primary metering rods
Incorrect secondary metering rods
Missing APT assembly
Missing inlet spring
Ruptured pulloff
Incorrectly set secondary AV spring
Incorrect power piston spring
Power piston hanger arms set at incorrect angle
Secondary throttle linkage bent and incorrectly adjusted
Carb 2:
Secondary metering rods incorrectly installed, jamming AV
Emulsion tubes fallen out of airhorn and incorrectly installed in wrong place in carb
Incorrectly set APT
Incorrect pulloff
Float clip incorrectly installed, jamming float
Carb 3:
Porosity in bowl casting causing uncontrollable idle circuit
Incorrect idle mixture screws installed
Bowl filler missing
Secondary rod hanger bent to wrong height
Missing fast idle cam
Warped airhorn causing air leak into primary metering circuit
On any 3 of these carbs, if you had simply cleaned the carb up, installed a kit, and put it back together the way it came apart, the carb would be a mess and never run right. This is the norm with Q-Jets due to their age. There is no secret setup procedure on the carbs: You have to identify the problems, replace or repair all the problem parts, set up to spec, and the carb will run right. If the carb is not running right, or if you have a bog, the carb has not been set up to its spec, and you have not fixed the problems in the carb.
