SBC Retro Roller Lifters
Old Mar 21, 2007 | 03:00 PM
28buick's Avatar
28buick
Default SBC Retro Roller Lifters
I am seriously considering installing a retro roller cam this spring. Is there a difference in quality or durability between Comp Cams, Crane or any other $450 retro roller lifter. Do I need to match manufactures or for example could I go with a crane lifter and an isky cam.
Old Mar 21, 2007 | 03:01 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Yep.
Larry
Old Mar 21, 2007 | 03:29 PM
28buick's Avatar
28buick
Who is the prefered producer.
Old Mar 21, 2007 | 03:40 PM
S489's Avatar
S489
the only thing about mixing is that no vendor will warrent their parts. in fact, ask vendor what parts are required to validate warranty. it was everything when i swapped: cam, lifters, springs. you also need them to tell you what dist gear to run, etc., etc.
Old Mar 21, 2007 | 07:12 PM
oregonsharkman's Avatar
oregonsharkman
I am in the process of rebuilding my 383. This time with a roller cam. I got the comp 286HR with all the matching parts......560/.560 lift@.050 230 duration @.050 110 lsa...steel magnum roller lifters....should be a monster
Old Mar 21, 2007 | 11:36 PM
King Lear's Avatar
King Lear
Veteran
I have the Crane HR-284-2S-12 IG 222/230 duration @.050 112 LSA .543/.563 lift with 1.6 roller rockers. I am very happy with mine. I did match all my componets in the valve train with Crane cams except I put in Manley Street Master Valves. I would not hesitate to use Comp Cams either. I would look at those new Thumper roller cams they have they looked to be pretty nice set up and sound.
Old Mar 22, 2007 | 12:55 AM
jackson's Avatar
jackson
As said ... match mfg for warranty. Contact Doug Herbert for all of it http://www.dougherbert.com/ ... about the best prices & all his rollers are billet steel & great quality ( as good as it gets) for as good a price as ANY ... spring for the iron cam gear option for an extra $50 ... it'll let you run a STOCK distributor gear ... you'll come out cheaper that way too. Typical Herbert true BILLET steel roller cam WITH friendly iron cam gear for sbc is about $250 total ... lifters priced accordingly.
FYI ... alotta big name roller cams ... most of em are not steel but are cast ... for same money or less you get Herbert true steel billet.
To SBC Retro Roller Lifters
