problem bleeding brakes
Old Mar 21, 2007 | 04:39 PM
74and76cpl's Avatar
74and76cpl
Default problem bleeding brakes
ok this is strang im have trouble bleeding my brakes. just put new cllipers on and now i cant get them to bleed with my vacume pump. maby have to wait till wife gets home and do it the old fashond way. maby im doing something wrong
Old Mar 21, 2007 | 04:42 PM
fauxrs2's Avatar
fauxrs2
Do it the old fashioned way - I've yet to get an adequate bleed from a vaccuum pump bleeder.
Old Mar 21, 2007 | 04:47 PM
74and76cpl's Avatar
74and76cpl
ok cool i was thinking is this silly thing out smarting me lol. and thanks for the fast reply.
crazywelder's Avatar
crazywelder
You have a ton of air in the system if you changed all 4 calipers and the vacuum pump isn't going to do much right now. Let it sit for a few hours with a full reservoir and the 6 bleeders open so that the fluid flows through. Once they are all dripping, then you should be able to bleed the old fashioned way, but it may take 2 or 3 attempts.
Old Mar 21, 2007 | 04:51 PM
74and76cpl's Avatar
74and76cpl
ok thank you good idea
Old Mar 21, 2007 | 05:01 PM
crazywelder
Also when you start bleeding with your helper, tap the top of the caliper with a rubber mallet while the bleeder is open to loosen more air bubbles. And make sure your helper doesn't release the brake pedal while you have the bleeder open. On the rears, do the inner bleeder first, then the outer.
Old Mar 21, 2007 | 05:07 PM
saudivette's Avatar
saudivette
Dunno if I'm getting the terminology mixed up but when you say vacuum pump is that the same as a power bleeder? Go here for a look: http://www.motiveproducts.com/index.html they make bleeding a breeze - well, it did for me anyway
Just to double check, are you bleeding in the correct sequence? LR-inner, LR-outer, RR-inner, RR-outer, LF, RF
Old Mar 21, 2007 | 05:29 PM
Artsvette73's Avatar
Artsvette73
I use the vacuum pump all the time. One thing I do before bleeding is remove the bleeder screw and wrap with teflon tape this will stop air from getting past the threads. And will stop the bleeder from rusting solid in the caliper.
Old Mar 21, 2007 | 05:56 PM
76 VETTE's Avatar
76 VETTE
I Bleed With A Vacumn Pump. I Usally Gravity Bleed First Then Use The Pump And Tap On The Caliper With A Rubber Mallet.works For Me
Old Mar 21, 2007 | 06:03 PM
schmegeggie's Avatar
schmegeggie
Recently did the same.
It helped to let new fluid run through to the line before connecting it to the caliper. That way I knew the fluid was there. Also, pre-filling the caliper helped too.
I used the Mity-Vac, but had a friend helping me with the bleeder screw. Made it easy. We bled each spot, in sequence, three times before I got a good pedal.
Did you replace the rubber lines? Mine looked good from the outside, but were shot on the inner tube. I also changed my Master Cylinder first. Are you sure the MC is good?
Just my $.02
Good Luck, C3 brakes are a bee-otch! The guy that helped me has a C2 and he was throwing around 4 letter words like nothing while we bled. Finally got it done though.
Old Mar 21, 2007 | 06:20 PM
74and76cpl's Avatar
74and76cpl
ok thanks all for your help wife is home i know she will know how to fix it.
Old Mar 21, 2007 | 10:03 PM
74and76cpl's Avatar
74and76cpl
well we got it to bleed with the old way of pumping took it for a drive and still acts like there is air in the line then when i went to park it i found a puddle on the drive way so i said thats enuff for today it was movie time i will look into it tomorrow. by the way Blood Diamond is a great show.
To problem bleeding brakes
