Help with warning buzzer please!
Old Mar 22, 2007 | 09:24 AM
Rick@Moroso Performance's Avatar
0Rick@Moroso Performance
Former Vendor
From: Moroso Performance, Guilford, CT, 203-453-6571
Default Help with warning buzzer please!
Hi,
My '78 sits a lot. It is fairly new to me, so I am still learning it. I keep it on a trickle charger so the battery is always ready to go just in case I want to drive it.
Within the last month, the "key is in the ignition reminder tone" has started going on at random. The key is NOT in the ignition. Usually I have to disconnect the battery to get it to stop. It seems to stop for a couple/few days, then it will start ringing again.
Any idea what could cause this? Where I should look?
Thanks for any help as usual!
Rick
Old Mar 22, 2007 | 09:32 AM
TimAT's Avatar
TimAT
The switch is in the column under the ignition lock cylinder. It may be gummed up and sticking. Not hard to get at, but you'll need to pull the steering wheel.
Old Mar 22, 2007 | 10:01 AM
Big2Bird's Avatar
Big2Bird
Intermittent faults are the hardest things to troubleshoot. I am not sure of 78, but in 81 the key buzzer and seat belt buzzer are 1 unit. It is transistorized. Judging from the many failures I see here of pulse wipers, tachs, dome light timers, and such. I would start there. Unplug the thing, and have it checked out.
I would also suggest purchase of the Helms manual, as it has a checklist to troubleshoot this item, and it's circuits.
Old Mar 22, 2007 | 01:35 PM
Jim Shea's Avatar
Jim Shea
Here is a link to a paper on trouble shooting the key buzzer system. However, as mentioned above, intermittant problems are very hard to figure out, unless you can catch it while the malfunction occurs.
http://jimshea.corvettefaq.com/wp-co...rDiagnosis.doc
Jim
Old Mar 22, 2007 | 01:41 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I have the same problem on mine. While I would l like to think it is the electronics, I do not believe that is it, as I have opened the module and is just a couple of transistors and resistors. From what I have read I believe it is the switch. I have read that simply by lubing the lock it will lube the switch as well, so I may try that. I really don;t care about the lock alarm, but this module also acts as the headlamp alarm. While I have never locked the keys in, I have left the lights on. I am going to fiddle with mine this weekend. I may even go so far as to remove the steering wheel again to pull the switch and replace it if I ahve to.
Old Mar 22, 2007 | 01:53 PM
7T1vette's Avatar
7T1vette
Your first course of action is to spray some WD-40 or PB Blaster (cleaner/degreaser) into the steering column lock assembly. Just put the little extender tube in the key slot and shoot a few times. You may want to aim it down, as the switch is below the slot. Then push the key in and out of the slot, and turn it to "ON" [not START] a few times to get the fluid down in the switch. The switch is "exercised" every time you insert the key, so this should loosen things up....IF the switch is just gummed up. Oh, don't squirt oil or graphite in there; that may be what stuck it in the first place (or just an accumulation of airborne oils/vapor0. Hope that works for you. Otherwise, you can disassemble the column to fix it correctly--or just pull the proper lead off of the horn relay [where the buzzing comes from], if you just want to stop it from buzzing.
Old Mar 22, 2007 | 08:03 PM
Big2Bird's Avatar
Big2Bird
The key clue here is it turns itself back on. I believe a stuck switch would not turn off. I find it hard to believe once off, it would restart. But, I could be wrong.
Old Mar 23, 2007 | 02:29 AM
7T1vette's Avatar
7T1vette
A continuity check of the offending switch (via the appropriate wiring) would determine if the switch was intermittent...or if it was stuck and the relay was intermittent (which is what I suspect). I still think the first attempt should be the easiest thing to try.
Old Mar 23, 2007 | 07:19 AM
Jim Shea's Avatar
Jim Shea
WD40 is not a lubricant. You can use it to clean things but the lock cylinder should be lubricated. The steering column engineers at Saginaw told me that a drop of synthetic motor oil on the tip of the key should be worked into the lock cylinder to lubricate it.
If you need to remove your key buzzer switch or the lock cylinder, complete instructions can be found at www.corvettefaq.com
Click on Jim Shea Steering Articles
Click on Corvette Steering Papers
Scroll down to the Standard (non-adjustable) or the T&T sections.
The information is in Paper #1 and Pic #1 as well as the Steering Wheel Pics for your type steering column.
Jim
Old Mar 23, 2007 | 11:08 AM
Former Vendor
Alright!
Thanks for all the input and info! I printed Jim Shea's article and I will start disassembling this weekend.
Thanks again everyone. I think I should be able to figure it out!
Rick
To Help with warning buzzer please!
