I know this is posted alot but Im still confused::
I see alot of Guys plug the Manifild and waterpump and remove the heater Hoses altogeather. Im interested in doing that But My 69 has a Surge tank, and the return hose from the heater core goes into the surge tank before returning to the waterpump. Is it still possible to Plug both at the engine and not use the surge tank , or is it best To Just plug the Manifold and then leave the return hose connected??
Thanks for any tips, advice.
If the water temperature is higher than you like, the heater core can also be used for cooling the water. Therefore, I suggest to leave the hoses in the system as designed!
The "surge" tank is required for the cooling system (pressure increase/decrease). Make sure it is always part of the cooling system!!!
I never did like the surge tank system, what it amounts to is a place where a big slug of air can accumulate. When the engine is running all the air collects in the tank, when the engine is shut off, some coolant collects in the tank lowering the over all level in the system. I converted my system to the recovery style by fitting a radiator hose filler to the upper radiator hose and using a late model C3 recovery tank in place of the surge tank. This puts the fill point higher than anyplace else in the system eliminating all the air, when you do that you have less chance of any air pockets being trapped in the engine.
And if you go this route you can fit a ball valve in a heater hose to block coolant to the heater core during the summer months.
Do you have pics of your setup? I never liked the fact that the fill cap is on my expansion tank lower than the upper radiator hose...
I'd 2nd the pics.
You must have an expansion tank somehere in the system. It's just the nature of the beast.
Take a look at a BMW system. It is very similar to the corvette separate exp tank system. There is a small tapered screw (a lot like a brake bleeder nipple) at the highest point (thermostat housing), to purge the system of air.
If you don't do it, their cars WILL overheat.
Sure, nothing special, easy and cheap to do. No "expansion" tank like we know it but a recovery tank making it a closed and fully filled system like the modern cars.
Sure, nothing special, easy and cheap to do. No "expansion" tank but a recovery tank.
Nice Mod...
I dont want to use the heater anymore, The core is old and could fail any time and the system Never was effective Heating the cab of my Vert anyway ..So,
I just got finished putting a Brass plug in the Manifold, and Tossing the Hose to the heater core away. Then I cut the return hose between the heater core and the Surge tank and Plugged the hose where I cant see it. Now I only have the hose from the surge tank to the water pump funtioning, Or I hope it functions Looks to me like I bypassed the heater correctly, does it sound right?. .
I just recently did my simular system. I plugged the manifold and water pump. then just used a short length of hose to tie the 2 serge tank connections together. My radiator is still hooked to the tank with a small hose. Seems to work fine. I could never understand why the heater hoses were routed through the serge tank anyway????????
Origionally, I just tied the two hoses together before the heater, and the water circulated through the tank, which is what it would do when the heater valve is open. Now, with no secondary loop, all the water is going through the radiator. Anyway, it droped the water temp a little.
