Clock question
Old Mar 22, 2007 | 05:46 PM
Lawton79's Avatar
Lawton79
Default Clock question
Has anyone been able to get their clock going or repaired?
Old Mar 22, 2007 | 05:56 PM
Roughrider's Avatar
Roughrider
There are vendors who will repair your clock but the best thing is to convert it to quartz movement. You can buy the conversion kit from any of the main Vette vendors or a complete reproduction clock with the quartz innards. Then just swap it out with your original.
I did that with both my '69 and '78 and they work perfectly and look identical to the originals. The only way it can be told that they aren't original is the stutter stop/go movement they have instead of the continuous sweep an original clock does.
Small price to pay for a clock that works.
Old Mar 22, 2007 | 06:17 PM
theandies's Avatar
theandies
I got a rebuild kit and did it myself. Piece of pie!
Old Mar 22, 2007 | 06:29 PM
73VetteKS's Avatar
73VetteKS
I took mine apart, filed the contacts, sprayed electrical cleaner to clean the rotating components, and then very carefully used a needle to put a very small amount of electrical contact lube on points of contact/friction. It has not worked for at least 15 years, but is now working, except when the car was setting for days when temperatures fell below about 30*. I bought the electrical contact cleaner and lube at Radio Shack.
-Jim
Old Mar 22, 2007 | 07:11 PM
7T1vette's Avatar
7T1vette
If you are not an absolute purist [where everything has to be by the book], change out the works to a quartz movement. If you want it to 'act' like the original movement, rebuild it with a similar movement. You can get either at ZIP Products. Most other sources only sell the quartz replacement.
Old Mar 22, 2007 | 08:13 PM
CCrane65's Avatar
CCrane65
I've done three of them so far. Be very careful with the tabs that hold the face onto the back they are fragile and can only be bent/straightened twice at the most.
Here is a link to a document detailing the procedure:
http://members.aol.com/jjneyjr/clock/grepair1.htm
The 10 cent version is use a can of compressed air to clean it out then spray WD 40 or light weight machine oil on all the moving parts, hook it up to a battery charger or some other 12 volt source and watch it for a few days to see how fast or slow it is.
There is a lever on the back of the mechanism near the bottom, you move it to the left to slow it down and to the right to speed it up. Move it in very slight increments as it will have a major effect on the speed.
The lever is very small and it is best if you look in the rebuild document as it has pictures showing it.
cc
Old Mar 22, 2007 | 08:54 PM
aussiejohn's Avatar
aussiejohn
Default Quartz IS the way!!!
Lawton,
Roughrider and others are right. Go quartz. Even I managed to fit one to my '74 and it still works five years later. And I live in the Antipodes, where water (and most clocks!) spin the other way.
Unless you have an NCRS show car and would lose points for a quartz movement, then this is the only way to go.
Regards from Down Under
aussiejohn
Old Mar 23, 2007 | 12:14 AM
marshrat99's Avatar
marshrat99
My 79's clock only took just a little TCL on the points and some WD40..been working great for 1yr+.
Old Mar 23, 2007 | 12:21 AM
Z-man's Avatar
Z-man
Mine stopped running...but it's still right 2 times a day.
Old Mar 23, 2007 | 12:27 AM
yukon988's Avatar
yukon988
cc
I fixed mine using this procedure and it has been ticking away for over a year now....
To Clock question
