Flywheels for Late model Blocks comment..
Old Mar 23, 2007 | 11:43 AM
69vettester's Avatar
69vettester
Default Flywheels for Late model Blocks comment..
Just thought Id Post an interesting parts incompatibility That I ran into when installing the zz383 engine in my 69.
Originally I thought any aftermarket Flywheel for a Late model (oem 1 piece seal) Block would all have the Same Bolt pattern as what GMPP sells for their ZZ engines.
So I decide on A Summit advertized "Hays Steel external balanced for GM late Block" and was amazed when it wouldnt bolt up..the Bolt Pattern was the Same Diameter but the Hole locations were off a hair in Radius.
When I looked back on the Summit Website I noticed that out of All the aftermarket Flywheels advertized for My Application, (Besides GMPP)Only Centerforce Noted: "Will fit GMPP ZZ engines". So I exchanged for the Centerforce and sure enough fit perfect, and cost $50 more!
When I sent The Hays Back I commented to Summit the Discrepency and wondered if they could verify with Hays the misfit with same advertized order criteria and get a Note in the discription "doesnt fit GMPP ZZ engines". That would have saved me Two weeks delay in getting my drive train togeather.
Out of all that I think I can Safely state the Fact that The GMPP ZZ Blocks do have "some" Propriatary issues with the Bolt up Components. Im not sure if its for better design Reasons Or is only a way To Force us ZZ engine folks into the GMPP market of component Parts Or any aftermarket company that will tool up and Comply to their different spec's. I suspect the Latter.
Microsoft Wrote the Book On this marketing teqnique. It works Very well for Profit margins But is Pure Pain in The Rearola from the consumer stand point. Starting to rant and rave now sooo....
Old Mar 23, 2007 | 01:27 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I thought that Microsoft invented this marketing technique......
Old Mar 23, 2007 | 01:31 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
wow, that is news to me too. i knew the new vs. old flywheel deal but didn't know about the ZZ variable. almost makes me happy i built my own late model truck block.
at least you got her figured out. now i hope you're enjoying her.
To Flywheels for Late model Blocks comment..
