hey lars, why not a sticky?
Perhaps one of them would be helpful to you.
http://lbfun.com/Corvette/Tech/vettetech.html
V8FastCars@msn.com
Lars
The following Tech Papers are available in MS Word format:
(NOTE: Articles vary in size from 50K to 1,500K in size. Normally, only 3 articles can be sent per e-mail. Keep this in mind when requesting “all of the articles”….)
How to Rebuild your Alternator (Rev. B)
BG Carb Installation (Rev. B)
BG Carb Setup (Rev. B)
How to Replace your C4 Brakes (Rev. A)
How to Install your Distributor (Rev. C)
HEI Ignition System Primers (Rev. New)
How to Tune Your Holley (Rev. B)
How to Adjust a Q-Jet Adjustable Power Piston (Rev. C)
How to Build a Fuel Line (Rev. G)
How to Rebuild your Front End (C2 & C3) (Rev. New)
How to Set Up Corvette IRS Rear Camber (basic do-at-home version) (Rev. C)
How to Set Your Ignition Timing (Rev. G)
How to Refinish & Repair Interior Plastic Pieces (Rev. New)
Handy Paint Mixing Formulas for Restorers (Rev. B)
Corvette Body & Paint Basics (applicable to steel cars, too) (Rev. C)
How to set up a Q-Jet Choke (Rev. New)
Q-Jet Problems I Have Seen (Rev. F)
How to Tune a Q-Jet (Rev. X)
How to remove & Clean your C4 Radiator (Rev. C)
How to Repair Rubber Bumpers (Rev. A)
How to Replace Your Timing Chain (C4 specific, but applicable to any Chevy) (Rev. B)
How to Determine Top Dead Center (Rev. A)
How to Adjust Your TPS and Idle Speed, Early C4 (Rev. B)
Vacuum Advance Control Units Facts and Specs (Rev. C)
Engine Vacuum Explained (Rev. New)
How to Adjust Your Hydraulic Lifters (Rev. A)
