Question about PCV valve for 82'
Old Mar 23, 2007 | 04:08 PM
Gunn353's Avatar
Gunn353
Default Question about PCV valve for 82'
I have a non-stock 82' with a 383. My question is 1) what exactly does a pcv valve do? pump oil up to both sides of the engine? 2) Do i need it if I am not running a stock set-up? I want to get rid of it since it is ugly and I found today that it hasnt even been hooked up to the vaccum
Old Mar 23, 2007 | 04:47 PM
73VetteKS's Avatar
73VetteKS
My understanding of the PCV valve is to basically vent the crankcase fumes back throught the engine to be bured through the exhaust. Most that I have seen are connected to the air cleaner. Since yours has been disconnected for some time, you have basically been running in the pre-PCV mode. I don't remember when the PCV came into play, but earlier engines, early '60's had a simple breather blugged directly into the valve cover, which vented the crankcase fumes into the air and sometimes could be smelled inside the car when windows are down.
Jim
Old Mar 23, 2007 | 05:04 PM
Gunn353's Avatar
Gunn353
Ah ok, I have a breather on one side already, is there any harm in puting a second breather in place of the PCV?
Old Mar 23, 2007 | 05:12 PM
bluthundr's Avatar
bluthundr
Nope, sounds like a plan to me. I am running just 2 breathers on my 76. The only way it could cause a problem is if your state has emissions testing/inspections.
Old Mar 23, 2007 | 05:15 PM
Gunn353's Avatar
Gunn353
Ok, thanks guys...luckily it's registered in Oregon (where i am from) and we dont have emissions laws there
Old Mar 23, 2007 | 05:31 PM
noonie's Avatar
noonie
You really should run a Pcv system of some sort.
Billet Specialties have some prettier ones if you're into looks.
http://forums.corvetteforum.com/show...ght=draft+tube
I have even seen oil dipstick tubes blown out at rpm from not running a Pcv system.
It realy helps keep your seals and gaskets from leaking.
To Question about PCV valve for 82'
