Yes i did a search and found nothing that suited what i was looking for. Well last night my 100amp summit alternator decided to take a crap. I need to know what alt that is 100+ amps will work. Its a 75 small block. I have dual electric fans, hella 90mm headlights and hella ff50 driving lights, Subs and Stereo. I need at least a 100 amp alt and it needs to be a 1 wire hook up because thats the way its installed when i installed the ez wirining harness last summer. Thanks in advance.
Here, this paper will walk you through the whole thing. Keep in mind you can use a CS130 or a CS144. If you go with a CS130, post that, so I can walk you through the process of modifying it for better air flow.
Are these 1 wire. I do not have a factory wiring harness I have a ez wiring harness. I need a 1 wire application. After reading through your write up can these alts be made in to a 1 wire I do not have the gen light in my car anymore I have full autometer gauge setup.
Yes. You need an inline resistor and some can be bought AS a single wire application.
No. The whole thing about the GEN light is that the bulb provides resistance for that brown or white wire that goes to the alt to tell it to charge. That's the one wire, and that's the important part to remember. Without resistance in that line the alt will never charge properly. Your kit may have included this somehow.
What you can do, is wire everything the way you have it. Take your one wire, spliced into a CS alt plug, and start the motor. Test the amt to see if it's generating 14V or if the engine is running off of the battery.
what cars or trucks might the one wire application come on.
I would search Ebay. They advertise them as one wire. I bought one by accident. They really are not very different. The second wire is just from the harness, and all it has is a constant 12V from the battery that I tie in with the BAT terminal on my installs. The third is a ground, and the forth is the BAT wire that goes to the BAT terminal.
I could be wrong but any CS alt will work on your one wire system.
A CS alternator will give you 100+ amps, and always more amps at idle, over the SI alts.
.........CS144 ....will give you around 100 amps at idle, and around 140 at RPM.
I will check on the difference between CS and SI, but what happens to all the amperage if he does not use it - is there any detrimental issues with excess amperage? I ask also because I need to upgrade my alternator now - ready to make a purchase.
There is no excess. That amperage is only generated as it's needed. If you have no lights, no fans, no nothing running, the alt will barely be generating anything...just enough to run the ignition system.
When everything is on, the system needs more juice and that one wire tells the alt, "Hey, lets kick it up a notch."
I now know the difference between SI and CS SI to CS Alternator Conversion
I will consider this for myself as I need (read: want ) more juice. So, if the ampeage is 'on demand', there is no reason why NOT to do this How does this translate to voltage issues?
If it's not generating, add a resistor.
ok if i do this what type of resistor would i need? and where you i put it.
I do not know what type resistor, but it'll be equal to what that GEN light bulb would produce.
It would need to be inline anywhere in front of the alt. Go ahead and try it without the resistor. If it charges fine then you don't have to worry about it. If it doesn't charge then install it.
A 3 watt 75 ohm metal oxide construction resistor needs to be spliced into the wire going to the L terminal. If you are running a MSD or similar ignition system you also need to install a diode that will prevent run on when you turn the ignition off.
What would happen if i did not run a resistor. My original 63 amp alt. worked with out the gen light being in the car. Then I upgraded to the Summit one that went out last night. So becareful about the summit brand alts. It did not even last six months and they only give a 90 day warranty. I just installed one i bought for a 90 vette per durango boys papaer. I have it wired like he says with the brown wire into a switched 12 volt source when the key is on. So will anything happen or just I just wait and get a resistor. I have ran the car and the volt meter was 14 volts and then when I turned on the electric fans and my head/driving lights it went to 13 so it looked fine. The case was very warm though. Thanks
