set the timing technique
Old Mar 24, 2007 | 06:24 PM
BIGJIM13's Avatar
BIGJIM13
Default set the timing technique
Guys
what is the best way/technique to set the timing correctly after the distributor has been taken out?
Old Mar 24, 2007 | 06:37 PM
jhuff's Avatar
jhuff
get a decent timing light
Old Mar 24, 2007 | 06:41 PM
TimAT's Avatar
TimAT
Pull #1 spark plug, stick your finger in the hole, and have someone bump the engine over until it blows your finger out. Look at the timing marks and rotate the engine until #1 on the timing marks isright around TDC. Drop the disty in with the rotor pointing where you want it to be for #1 plug wire on the cap. Gently puch down on the disty, have someone bump the engine over until the oil pump shaft lines up- you can tell when the disty drops that last 3/8 and seats on the manifold.
Install the cap, wires, and set the timing. Lock the disty down-- Done! Go drink a beer.
Old Mar 24, 2007 | 08:47 PM
BIGJIM13's Avatar
BIGJIM13
got the beer part covered - is that pretty much it on setting the timing?
Old Mar 24, 2007 | 09:40 PM
SmokinBBC's Avatar
SmokinBBC
Originally Posted by BIGJIM13
No. That's just dropping in the dist.
See the sticky post at the top of C3 tech by Barryk for instructions on setting your timing.
Old Mar 26, 2007 | 02:00 PM
BIGJIM13's Avatar
BIGJIM13
TimAT
when you say
"Look at the timing marks and rotate the engine until #1 on the timing marks isright around TDC"
do you mean rotate the engine to line up the timing mark on the balancer with the Zero on the tab?
Old Mar 26, 2007 | 03:02 PM
Hvymtlc5's Avatar
Hvymtlc5
Yep - then check your distributor rotor...it MUST be pointing to the #1 spark plug terminal on the dist. cap. If it isn't you have something wrong....
Old Mar 26, 2007 | 06:01 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
Pull the valve cover and make sure the valves on the #1 cylinder are closed when lining up the timing mark or you'll be 180 off in your timing. The crank turns twice for every one rotation of the distributor.
To set the timing technique
