More Hydroboost ??
Old Mar 25, 2007 | 05:06 PM
SIXFOOTER's Avatar
SIXFOOTER
Default More Hydroboost ??
OK, sometime back someone posted some hydroboost pics. I hyjacked one of them for my use and now that I am ready to mount mine I have a ?? or two.
Here is the ref pic I have
It shows the shaft length to be about 2 3/4" from the end of the snout of the HB Unit...ok
This is the same measurement on my HB Unit, as you can see they look a bit different
That looks way short to me, How much travel is needed for the brake shaft?
2 3/4" is the measurement from the mounting surface on the Vab Brake booster to the back of the shackle for the brake pin, but if I cut the shaft on my HB unit will that work? Will I have enough shaft left?
TIA
Danny
Old Mar 25, 2007 | 10:52 PM
Durango_Boy's Avatar
Durango_Boy
I can measure the travel for you tomorrow. However, I think if you just cut your shaft to 3.25", and set the correct length for the clevis...the excess can be trimmed if needed.
Old Mar 25, 2007 | 11:04 PM
mrvette's Avatar
mrvette
DB, I looked that the pix side to side, and I could not really get a good enuff look at the lengths involved due to the aspects of pix, and placement of rulers.....one is a given....so we need try interpolating....
I suspect there maybe not enough throw on the new HB install for the full displacement of the master cyl.....I dunno, really....
so I hesitate to lend advice.....I need experiment with my car a bit more on that score, as I want the brake pedal lower to the floor, and the gas pedal too....but that means a longer pedal on the pull end...welding, and pulling the m/cyl off the HB, and checking throw, vs the throw on a m/cyl....to see if I can really cut the input shaft any further .....or bend/weld the pedal yet again...
decisions, decisions....such is hotrodding...find a solution, go back and rethink it again, and live with it ...think again...and....hell i'ts never over....
Old Mar 25, 2007 | 11:07 PM
Durango_Boy
Like I said, I will get some measurements tomorrow of the shaft at full travel and full rest. I will use a tape and two pics.
Old Mar 25, 2007 | 11:09 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
the top pic they are measuring from the end of the snout, on the second pic you are measuring from the mounting surface. I think this is causing some confusion. Because the two units are different I don't think you will be able to use the measurements from the top pic. I don't remember the measurements from when I did mine right off the top of my head. I measured from the mounting surface of the HB unit to the center line of the clevis pin.
Neal
Old Mar 25, 2007 | 11:48 PM
chris75stingray's Avatar
chris75stingray
Neal
don't measure off the snout because they might not all be the same
Old Mar 25, 2007 | 11:50 PM
SIXFOOTER's Avatar
SIXFOOTER
Neal
Yea, I knew that as soon as I looked closely at the pics before I posted.
I ended up measuring from the outside of the firewall to the center of the clevis pin hole with the pedal all the way up and cut the shaft for that with about 1/2" adjustment on both sides of that. I think it will work, but will be a while before I can verify. I made a mount plate asuming (like an idiot) that the bolt pattern was square, it ain't.
So I got to make another plate tomorrow.
Matt, I ain't forgot about you.
I fabbed a pin for the unit, 3.45" I think was what was needed. Had to make 2 of those too. Ended up cutting one a little long and adjusted it down until the HB and MC just fit together without compressing the MC piston. Worked out pretty good. The plastic disk that keeps the pin centered in the HB Piston was inside the spring.
Old Mar 25, 2007 | 11:54 PM
Durango_Boy
Some are square. Mine is, and many of the ones I deal in are. It depends what they came off of. some or nothing even close to square.
Can't wait to see pics of yours.
Old Mar 26, 2007 | 12:45 AM
SIXFOOTER's Avatar
SIXFOOTER
The hole pattern for the existing Vac booster is ot square. The HB unit only has the central mount nut.
SO your firewall bolt pattern is square? Mine is about 3/8" taller than wide.
To More Hydroboost ??
