Timing question
Old Mar 26, 2007 | 10:31 AM
blue by you's Avatar
blue by you
Default Timing question
Pulled the dist to check croos gear on shaft (71 stock with points).Put the dist back in seams to run alittle rough. I did mark where the rotor was and marked the housing to the block. Should I just reset the timing or do I need to check any thing else.
Old Mar 26, 2007 | 11:32 AM
Big2Bird's Avatar
Big2Bird
Follow the stickey at the top of this page.
Old Mar 26, 2007 | 11:34 AM
BarryK's Avatar
BarryK
redo your timing.
marking it before you removed the distributor is a big help during re-installation of the distributor in terms of making sure it is oriented correctly and it's in a close range but it won't be exact.
Throw a timing light on it and set it up correctly
Old Mar 26, 2007 | 12:53 PM
blue by you
Thanks, I just wanted to make sure I was on the right path
Old Mar 26, 2007 | 03:43 PM
lars's Avatar
lars
Yes, you have to re-set timing any time you pull the distributor. Just lining up the marks won't get you close enough. Put a light on it and get that total timing set at 36 degrees.
Old Mar 26, 2007 | 08:32 PM
blue by you
Thanks Lars, you just saved me from another post
To Timing question
