Ball joint rivet removal
Old Mar 26, 2007 | 11:44 AM
Oldguard 7's Avatar
Oldguard 7
Default Ball joint rivet removal
What is the best way to remove the rivets on both the upper and lower ball joints?
Old Mar 26, 2007 | 11:45 AM
Big2Bird's Avatar
Big2Bird
Drill the heads off, and pop out the pin.
Old Mar 26, 2007 | 11:52 AM
1B.DZ's Avatar
1B.DZ
I just drilled mine out and then you should be able to bolt up the new ones, right? Shouldn't be too much trouble.
Josh
strokervette's Avatar
strokervette
You can also use a wiz-wheel or angle grinder to take the heads off. I've also used a pnuematic chisel.
Old Mar 26, 2007 | 12:11 PM
NHvette's Avatar
NHvette
Angle grinder is fastest with little risk of damage to control arm.
Have a heavy punch ready to pop them out ... punch on an air hammer is best.
Old Mar 26, 2007 | 12:41 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I had to cut the edges off of the ball joints, then grind the rivet flush with the arm before they'd pop out.
Old Mar 26, 2007 | 03:04 PM
Garys 68's Avatar
Garys 68
I just ground my uppers flush last weekend and they still wouldn't pop out with a punch. Tight rivets I guess. Fastest way for me was to grind most off, drill a hole in the center, then punch them out.
Old Mar 26, 2007 | 03:07 PM
JPhil's Avatar
JPhil
Grind off the head, drill the shank, insert punch, SMACKO!
Old Mar 26, 2007 | 04:32 PM
redc3's Avatar
redc3
dont waste time drilling
Old Mar 26, 2007 | 04:50 PM
jdmick's Avatar
jdmick
4 1/2" angle grinder down as far as you dare. I also heated what was left with an acetylene torch before punching them out.
Talisman51's Avatar
Talisman51
Default drill-em..
For uppers...drill em from the non-peened side (under a-arm) with a larger drill than the rivet shank diameter... The head will spin off once thru the head and then pop em out with a punch....NO damage to ball joint or A-arm.
Old Mar 26, 2007 | 05:29 PM
big_G's Avatar
big_G
Air chisel with a good bit takes about 3 seconds each. Then switch over to an air punch bit and 3 seconds for each rivet head. All done!
Old Mar 26, 2007 | 06:41 PM
enkeivette's Avatar
enkeivette
I used a dremel tool with a reinforced cutting wheel, cut off the heads (on top of the arm), and shaved any remaining edges off. Then I smacked the ball joint stud on the concrete a few times till the ball joint pushed itself out.
Old Mar 26, 2007 | 11:24 PM
CCrane65's Avatar
CCrane65
Last time I had to do this job was in 1974 and I did it with a 5lb sledge and cold chisel. Took 20 minutes per rivet because I was a 123 pound sailor just out of boot camp.
A pnuematic chisel would have been wonderful. But hey, my arms got quite a workout!
cc
Old Mar 27, 2007 | 12:12 PM
68/70Vette's Avatar
68/70Vette
Good suggestion. My control arms are powder painted and I'd like to replace the ball joints without scratching the paint. Working on top of the ball joint should save the paint. (Using a power chisel on the bottom sounds like the fastest way, but it would scratch a lot of point. Oh...occassionally when I've scratched powderpainted surfaces, using POR15 to touch up the scratch has worked pretty good.)
To Ball joint rivet removal
