Headlight Problem
Old Mar 26, 2007 | 07:58 PM
sweetshark71's Avatar
sweetshark71
5th Gear
Default Headlight Problem
Hey guys,
New Corvette owner here -troubleshooting my second problem!
I've got a headlight issue on my '71 Stingray that's causing me problems. I've swapped the lamps around to no affect so I guess it's wiring/connector related. On low beam setting, all I have is the driver's side beam; on high beam setting all I have is passenger side high and low beams - it's odd to me that the driver side low beam goes out when I click to high beams.
Any ideas on where I need to start looking next?
Thanks!
Old Mar 26, 2007 | 10:53 PM
SIXFOOTER's Avatar
SIXFOOTER
Maybe a bad ground, follow the cable from the pass side to the drivers side from the connectors, its there somewhere
