68 casting#
Old Mar 26, 2007 | 11:04 PM
TPIC427's Avatar
TPIC427
Default 68 casting#
Help-
I've got a 68 vette with a clean pad. casting # 3914660
where the date should be is convt or convi (not sure)
the car is a very early build-10/67. Certain reference books say this is correct for an early 68, others do not mention this #. Any help would be appreciated. Thanks-Tpic
Old Mar 26, 2007 | 11:43 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by TPIC427
Help-
My Corvette by the Numbers book says: 1968 Corvette 327 300 HP. It was used interchangably with the 3914636 block in certain applications. There is some evidence that this block was used prior to a Feb 29 1968 assembly date. Note: all applications are unverified.
Look at the same spot as the casting # on the opposite side. Should be a casting date there.
Old Mar 27, 2007 | 03:54 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
most 68's I've seen have a 3914678 casting for all 327's.
Old Mar 27, 2007 | 08:36 PM
Mike Ward's Avatar
Mike Ward
Look down on the right (passenger) side of the block above the oil pan. If you find the casting date there, this might be a McKinnon Industries block.
Old Mar 27, 2007 | 09:05 PM
JackDidley's Avatar
JackDidley
Conv 1 means it went down conveyor 1 when it was cast. Took me 25 years to learn that.
To 68 casting#
