Headlight assembly removal question
Old Mar 26, 2007 | 11:05 PM
ctrain22's Avatar
ctrain22
Default Headlight assembly removal question
Before I tackle this job, Can anyone tell me how the remove the headlight assemblies? The assemblies on my 70 are frozen in the closed position. I want to take them out as a comlete package if possible to rebuild them.
Old Mar 26, 2007 | 11:34 PM
SIXFOOTER's Avatar
SIXFOOTER
you can get to the critical parts from underneith, behind the air dam, This of couse means the front will need to be jacked up. May also need to pull the grills to get to the parts
Old Mar 27, 2007 | 08:00 AM
Tommy Samuels's Avatar
Tommy Samuels
it's easiest with the front end up about a foot, grilles out for better access. 5 bolts hold the horseshoes in place. chances are they'll be rusty, so spray with WD30 ahead of time. Once you get 'em loose it's a twist /wiggle/ swear/ pray job to get them out the bottom.
Old Mar 27, 2007 | 08:22 AM
Edzred72's Avatar
Edzred72
BE WARNED If your pulling the headlight supports (horseshoes) be very gentle with them. They are cast pot metal...and extremely brittle. Look at em wrong and they'll crack.
My advise is to pull the bucket assembly first, then pull the horseshoes by themselves. Remove actuator arm from headlight bucket linkage. Each assembly is held in by swivil bearings. Three bolts hold each bearing to the car. Each door pivot arm (goes inside bearing) has a collar that holds it centered...the collar has a set screw. Loosten screw, and slide collar. Should be able to wiggle out assembly.
You should really look at a detailed view of the headlight assemblies before you start. DocRebuild has a great one in his catalog. Other vendors might also.
Eddie
Old Mar 27, 2007 | 12:08 PM
68/70Vette's Avatar
68/70Vette
You can still buy all new parts- all of the little rods, shafts, levers, bearings, etc. But after tearing the original mechanism apart, and replacing it with new components, getting it into adjustment so it works correctly can be very difficult/tedious.
Assuming your headlight assemblies have not been bothered with since they came from the factory, with only corrosion now preventing their operation, you should note all the original factory adjustments. Maybe spay paint on the original mechanism, so when you dismantle it you can see how far this part was screwed into that part. Another strategy would be to repair one at a time; i.e. repair the right headlamp assembly completely before starting on the left, etc.
The assembly, to me is a little of an engineering marvel. After you replace all the bits and pieces with new, it really looks nice.
Old Mar 27, 2007 | 06:16 PM
NHvette's Avatar
NHvette
Really frozen ?
The linkage is designed with a knee to lock down unless the vacuum pulls it up.
This can be overridden by pulling on the knee linkage while
simultaneously trying to push the headlight up.
You may just need actuator/vacuum relay, or just a hose.
Mine came out, but much of the hardware was frozen and broke when
trying to loosen ... can of worms at best.
Good Luck
Old Mar 27, 2007 | 10:46 PM
ctrain22's Avatar
ctrain22
Unfortunately, It seems to be frozen. Everything else has been. That's what happens when you neglect and keep a car outside or in a cold barn for 16 years.
By linkage, are you talking about the linkage from the acutator? If I disconnect the linkage from the assembly, should it move freely (if really not frozen)? I have been working my way forward from the rear on this project (with some detours on the way). The wiper dooor was frozen, although I was able to get the linkage free there, and worked it out. They now work fine, but suspect the headlights are also frozen. Does anyone have a picture of the linkage? I have the Dr Rebuild catalog, but only shows a parts diagram.
Old Mar 28, 2007 | 12:41 AM
chris73cpe's Avatar
chris73cpe
this is partially disassembled already, but it should give you an idea. the 3 bolts on the bottom right hold the rear pivots, there's one on the other side too. there is a long pin that goes through the hole where the circle is that the springs attatch to, and the black thing to the left of that is the switch that contacts the flat spot to the right when they are open. I actually pulled this one out to weld a crack in the housing, but i replaced all the bushings and regreased it while it was out. I was able to do all the bushings on the other side still on the car, although I did have the front bumper off at the time.
Old Mar 28, 2007 | 02:14 AM
ctrain22's Avatar
ctrain22
Chris....great picture. Now I have an idea what I will have when I start to take them apart. Looking at your picture and Dr Rebuilds diagram makes sense now.
To Headlight assembly removal question
