Anyone using polyurethane trans. mount
Old Mar 27, 2007 | 06:37 AM
The Corvette Kid's Avatar
The Corvette Kid
Default Anyone using polyurethane trans. mount
I just received my Energy Suspension polyurethane trans.mount and it is about 1/2 inch taller than the factory mount. Is this going to cause a problem with driveline angle or vibration. Anyone else using this mount, Thanks, Bob
Old Mar 27, 2007 | 08:56 AM
cherrybombc3's Avatar
cherrybombc3
lurk:
Also curious......I have one here and wondered the same thing. Dont believe it will hurt, but leary enough where I havent installed it yet.
Old Mar 27, 2007 | 10:38 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I don't remember what brand mine is but I think I remember a similar issue. Haven't had any problems with the poly mount. It is certainly better than the 2 or 3 rubber ones I went through before installing this one.
Old Mar 27, 2007 | 10:58 AM
pws69's Avatar
pws69
This is a known issue with the ES trans mount and ES has never corrected it - it has been discussed here in the past more than once. Most people use a stock trans mount with the ES Motor mounts (as I will probably to do). I only remember of one person who said they actually used the ES Poly trans mount (anyway!).
Old Mar 27, 2007 | 11:56 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Yeah i remember a couple of those threads. It was believed that the poly's will throw the driveshaft angle off causing a vibration. Don't know how true it is but thats what I seem to remember.
Old Mar 27, 2007 | 12:10 PM
88turboGT's Avatar
88turboGT
This is true. Both u-joints must be at equal and opposite angles. This will cancel out any vibrations. If the front joint is off …it will vibrate.
Old Mar 27, 2007 | 12:18 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Old Mar 27, 2007 | 01:17 PM
Tommy Samuels's Avatar
Tommy Samuels
Is that 1/2 inch taller than a new factory mount or a used one? Rubber compresses quite a bit over time.
Old Mar 27, 2007 | 01:33 PM
pws69's Avatar
pws69
I believe it is new ones. I have a new one of each at home - I'll chack later this afternoon.
Old Mar 27, 2007 | 01:55 PM
S489's Avatar
S489
i have urethane tranny and engine mounts on mine - no drivetrain vibration. i'll have to look up the brand and post later. the original factory type was so mangled, i wouldn't have known of the height difference. in fact, the new engine and tranny mounts may have fixed a vibration . . .
Old Mar 27, 2007 | 04:57 PM
marshrat99's Avatar
marshrat99
I was using the Energy Suspension polyurethane trans.mount on my 79's TH350 before replacing it with a BTO 2004R tranny and a BTO xmember. I did not experience any vibrations with the TH350 nor have I had any with the 2004R using the same mount. When replacing the original I noted that the ES was thicker but dismissed it as being new compared to my mangled original.
Old Mar 28, 2007 | 05:34 PM
pws69's Avatar
pws69
Sorry for the delay!
Here's what I have:
1 - New - Energy Suspension "Kit" - Motor Mounts + Trans Mount
1 - New - GM Trans Mount
Here's what I found:
The Trans Mounts are essentially the same dimensions (metal to metal) in every way. The only difference with the ES mount is that there are 2 "dimples" on the bottom that protrude about 1/16 inch below the bottom of the metal surface - they are in the center about 3/4 inch apart where there is more poly than metal - they will surely compress when the bolts are tightened.
There ya have it - measured with digital calipers and all! I'm psyched - I can use the Poly mount now!
Old Mar 28, 2007 | 05:48 PM
enkeivette's Avatar
enkeivette
I have it underneath my T56, the driveshaft is really close to the seam in the tunnel underneath the e-brake. There is no way that I could have fit the mount and the supplied plate in there, too tight.
No vibrations though.
I was thinking about taking it out and shaving off 1/2" or so. The embeded metal plate is pretty thick...
Old Mar 28, 2007 | 05:51 PM
enkeivette's Avatar
enkeivette
Here's what I have:
My trans poly mount was taller for sure. You must have a newer version or something.
Old Mar 28, 2007 | 06:32 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
How tall is a new rubber mount? I need to measure my uninstalled ES mount when I get home next week.
Old Mar 29, 2007 | 06:40 AM
pws69's Avatar
pws69
I believe I bought these the same time people were claiming the difference so it's not "newer" in that respect.
Did you compare a new ES with a new GM? Also there is a different mount for the Auto vs. 4 spd for earlier C3 years. What year is your vette?
Old Mar 29, 2007 | 09:37 AM
jackson's Avatar
jackson
The Trans Mounts are essentially the same dimensions (metal to metal) in every way.tightened.
So ... what are the dimensions of each? Regardless when they were bought ... what are dimensions of each?
To Anyone using polyurethane trans. mount
Old Mar 29, 2007 | 08:21 PM
pws69's Avatar
pws69
1 13/16" high
Old Mar 29, 2007 | 08:33 PM
enkeivette's Avatar
enkeivette
78, originally auto.
Old Mar 29, 2007 | 10:13 PM
Steve439's Avatar
Steve439
Poly motor mounts and stock trans mount has worked for me.
