Tinkling sound
Old Mar 28, 2007 | 10:29 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Tinkling sound
Here's the first thread I started.... http://forums.corvetteforum.com/show...light=tinkling
I was just speaking to another engine guy and he said it might be my solid lifters that I hear? Any truth to that?
Old Mar 28, 2007 | 11:20 AM
JPhil's Avatar
JPhil
Could be.....
Here's an idea I used on my ol' Chevy truck to listen to the engine while driving. I used 1/4" +/- plastic hose poked through the firewall to a tee with one end going to each side of the engine. Stuck tiny funnels in the ends as an "ear trumpet." It took trial & error to find positioning where the underhood wind noise didn't overwhelm the engine sounds. The other end came into the cab and I could stick it in my ear to listen. A big stethescope. You could probably use the end from a genuine stethescope hooked onto your tubing, and secure the rod to a valve cover (or wherever) for better hearing.
Just a thought.....
John
Old Mar 28, 2007 | 11:47 AM
Husband1166's Avatar
Husband1166
Hi Jughead
My clutch had fragmented and peices were being thrown around making the same sound..... the fact that you don't have the inspection cover would make me think they would fall out.... worth a look maybe.
Pete
Old Mar 28, 2007 | 12:16 PM
Big2Bird's Avatar
Big2Bird
You state it is on decelleration only. During that time period, there is a great increase in vacuum. Try looking at vacuum operated items that may have slop. IE, headlights, heater valve, etc. The spike in vacuum might make something rattle. I had a vacuum EFE that drove me crazy till I checked it out.
Old Apr 23, 2007 | 01:43 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
No, I was wrong it's not on decelleration but at constant engine speed.
I had the vette out yesterday trying to find the source. One item I can rule out is any clutch-flywheel noise. When I push the clutch pedal in but keep the rpm's the same...the noise doesn't go away.
I'm going to check the valve lash maybe next weekend.
To Tinkling sound
