Help! Rochester Quadrajet Choke problem
Old Apr 22, 2007 | 06:56 PM
Mikeg72's Avatar
Mikeg72
Default Help! Rochester Quadrajet Choke problem
I have a "72" 454 with a Rochester Quadrajet. The car starts fine when cold and runs great until I shut it off. (vacuume choke). When I try to restart (warm engine), the coke plates close and it refuses to start. I have to take off the air cleaner and hold the choke plates open and it starts right up. (hard to look cool when you have to ask a stranger to hold the choke plates open at the local Ice Cream stand)
If I wire the plates open, (yea you guessed it) it won't start when cold.
Ouch! Kinda takes the fun out of driving that beautiful beast.
Any helpful tips? P.S. I'd love to junk the carb for a new Holley or Edelbrock carb but I'd like to let the credit card cool off until next year and find a fix for the current carb for this year.
Thanks!!
Mike
Old Apr 22, 2007 | 07:08 PM
wombvette's Avatar
wombvette
The choke pull off is bad.
Old Apr 22, 2007 | 07:10 PM
tellcom2001's Avatar
tellcom2001
i put an edelbrock on mine with a 350 hp motor the edelbrock isnt my first choice for a carb im going to rebuild my q-jet my edelbrock 600 cfm had to change the main squirt,metering rods,springs,and now the accelerator pump,and who knows what next..dosent get enough fuel
Old Apr 22, 2007 | 08:02 PM
dgruenke's Avatar
dgruenke
Have you tried adjusting the choke? I believe there are a few screws that hold the choke onto the carb. You can loosen those and rotate the choke until the plates are in the correct position.
Old Apr 22, 2007 | 08:55 PM
noonie's Avatar
noonie
It shouldn't close if the engine is still warm.
Check the bimetallic adjustment and operation of the pull off.
Old Apr 23, 2007 | 05:26 AM
aussiejohn's Avatar
aussiejohn
Default Stick with the Q-jet
Mikeg,
General Motors knew what it was doing when they decided to put a Q-jet on your 454. Just follow the advice of noonie and others and a simple repair will fix your problem. Your car is 35 years old!!! So is the carby!!! Some things just wear a little bit and throw the whole "balance" off. Fix the choke and the "balance" of the whole carb will return to where it was before this problem reared its head. Spend a little more and get the whole carb freshened and the car should run like new.
Regards from Down Under
aussiejohn
Old Apr 23, 2007 | 12:41 PM
427-390's Avatar
427-390
Originally Posted by aussiejohn
Mikeg,
aussiejohn
Excellent advice!
Old Apr 23, 2007 | 02:02 PM
lars's Avatar
lars
The 72 Q-Jet uses a choke pulloff with a spring wound around the pulloff arm. This spring causes the choke to close any time the engine is shut off - even if the engine is hot. The intent was that by closing the choke on a hot engine, the engine would re-start without touching the gas pedal, followed by the pulloff retracting and pulling the choke plate open. But I see this not working very well in many applications. To fix it, simply take a pair of snips and cut the spiral-wound spring off of the choke pulloff arm. This will allow the choke to stay open when the engine is hot. It will close normally when the engine is cold. (This all assumes that your choke pulloff is functional... suck on it to check it).
To Help! Rochester Quadrajet Choke problem
