restricted return line system?
Old Mar 28, 2007 | 04:53 PM
blueray72's Avatar
blueray72
Default restricted return line system?
Whad tha? Well in an effort to not hijack Mybad79's thread about aftermarket fuel pumps.......
Can someone please explain how to do this? Lars mentioned it is done at the inlet of the carb.
I'm using a pump with one inlet and one outlet. I would like to use this pump, as it's new and "shiney".
Old Mar 28, 2007 | 05:15 PM
Durango_Boy's Avatar
Durango_Boy
You can tap a return line anywhere after the pump before it gets to the carb. The closer the better. Just make sure the return is a size down in tube diameter. This way the fuel goes where it's needed and the excess pressure is bled out and through the return line to the tank.
Old Mar 28, 2007 | 05:45 PM
lars's Avatar
lars
Install a "T" as close to the carb inlet as practical. Using "AN" fittings makes the plumbing job a bit easier. Using a -6 AN Tee, install a reducer off one of the T legs to drop the size down to -4 (1/4"). Plug weld the reducer closed, and then drill a 1/16" diameter hole in the weld plug. This will allow a steady stream of fuel to return to the tank without lowering fuel pressure or adversely affecting flow delivery to the carb. Works great.
If you want to get a bit fancier, use a Mallory return style regulator and "T" it in just before the carb.
Old Mar 28, 2007 | 05:52 PM
bluthundr's Avatar
bluthundr
I did the same as above, but I jammed an old carb jet in the rubber line close to the steel line side and used that to restrict the flow. Works great so far.
Old Mar 28, 2007 | 06:12 PM
blueray72's Avatar
blueray72
Excellent. I was thinking about using a regulator, but I'd like to keep the cost under $40. That's about the price of a new pump.
Old Mar 29, 2007 | 12:53 AM
Artsvette73's Avatar
Artsvette73
Did the same to mine only I drilled and tapped the return fitting and screwed in the jet
Old Mar 29, 2007 | 01:01 AM
Ironcross's Avatar
Ironcross
Most of the automoblies using a return line are air conditioned. Corvettes are no exception. Performance engines do not require them or regulators if it`s a mechanical pump as they normally max out just under 7 lbs. or less, just enought to keep the needle on it`s seat..
Old Mar 29, 2007 | 01:04 AM
Big2Bird's Avatar
Big2Bird
Oh I GOTTA ask this one. What does A/C have to do with the need for a return line.?
Old Mar 29, 2007 | 05:21 AM
woodlandcorvette's Avatar
woodlandcorvette
My jeep has its return on the fuel filter that you car buy at any auto store if you dont want to tap the fuel line. I thought of using it on my vett if I get a fuel pump like the one you want to use. Just a thought there are a few options.
Best Regards
Old Mar 29, 2007 | 07:27 AM
bashcraft's Avatar
bashcraft
Is there any reason to do this if you're NOT having problems with vapor lock.
Old Mar 29, 2007 | 10:04 AM
gofastvette's Avatar
gofastvette
Yes, I can handle this. It helps prevent vapor lock and hard starting on AC equiped mechanical fuel pump applications. Both the BB`s and SB engines use them on the low HP models where almost allways AC is standard equipment. Not necessary with high performance engines sir.
PS, no reason to add a return line if no vapor lock appears
Old Mar 29, 2007 | 06:36 PM
Durango_Boy
That's what I was wondering.
Old Mar 29, 2007 | 07:02 PM
Ironcross's Avatar
Ironcross
Not really, non of the high HP Chevys have the return lines except the more recent FI engines equiped with electric pumps.
To restricted return line system?
