Removing anodizing on rocker trims?
Old Mar 28, 2007 | 08:39 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Default Removing anodizing on rocker trims?
I have heard that oven cleaner will do this, but I have also read that it doesn't work very well, so has anyone done this with success? I want to remove the anodizing and polish the trims, so any advice is appreciated!
TIA
Old Mar 28, 2007 | 09:29 PM
dannyman's Avatar
dannyman
Check this out;
My 82's re-assembly photo's - thread # 626 - last page of post
82 MDVette
Old Mar 28, 2007 | 09:32 PM
sjmaster's Avatar
sjmaster
I have tried various ways to remove anodizing from alum, including mechanical removal, and the results were always less than satisfactory. But, I may not be aware of the correct way. Successful removal is also a function of how deep the treatment is. To be clear, I have never tried it on the rocker panels, but have on other thin stock. Mechanical would probably work, working up in grit numbers towards 1000, but the recessed areas and work hardening from the stamping process may make getting an even shine very difficult or impossible.
I think alum can be chromed...I would sure investigate that first.
Old Mar 28, 2007 | 09:50 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I started with 220 or so on a DA, worked down to 600 and buffed with Mothers Mag and aluminum polish..........
Old Mar 28, 2007 | 10:04 PM
7t2vette's Avatar
7t2vette
Looks awesome! So you didn't start with chemicals at all, just hit it with sandpaper?
Old Mar 28, 2007 | 10:07 PM
frostbitten09's Avatar
frostbitten09
I used a strong paint remover, Then a buffing compound for mine.. O ya and used a toothbrush with the Paint remover and it came right off. (i got the strongest kind i could buy)
Old Mar 28, 2007 | 10:11 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
That's correct, the coating isn't hard to remove. You can see the metal change color as it comes off.
Old Mar 28, 2007 | 11:01 PM
7t2vette's Avatar
7t2vette
Sounds almost too easy! I was dreading trying the chemical route, but this will be much easier! Thanks mang!
Old Mar 28, 2007 | 11:09 PM
jim2527's Avatar
jim2527
Easy off oven cleaner worked on BMX parts back in the day. Outdoor use is a must!!
Old Mar 28, 2007 | 11:13 PM
sjmaster's Avatar
sjmaster
WOW 7t2vette that is fantastic !!!! Do I see a black filler strip where recess is??
Now, another project has been added to the list.
Old Mar 29, 2007 | 05:02 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Yes, I painted the recess black.
Old Mar 29, 2007 | 03:09 PM
Scott Marzahl's Avatar
Scott Marzahl
The Anodizing isn't that deep, .010" at the maximum. The chemical(s) you need to remove it are either lye or muratic acid and they both love to eat aluminum. You could brush on some muratic acid and CAREFULLY watch it, as soon as it starts bubbling like crazy get it off with water before your rocker panel trim is gone. The trim will look like crap and you'll still need to sand and buff it.
Old Mar 29, 2007 | 08:28 PM
7t2vette's Avatar
7t2vette
Thats why I am going to give the DA sander a shot instead of the chemicals!!
To Removing anodizing on rocker trims?
