'75 auto-manual conversion
Old Mar 29, 2007 | 09:27 AM
tomas35's Avatar
tomas35
5th Gear
Default '75 auto-manual conversion
I own a 1975 auto corvette and I would like to fit a new 5 speed manual transmission in it. What can you tell me about the converion kits in te market and the work to fit them?
Excuse my english I live in Spain! Thank you
Old Mar 29, 2007 | 09:30 AM
Binnie77's Avatar
Binnie77
Check out this link:
http://www.corvettec3.ca/tko.htm
Old Mar 29, 2007 | 02:04 PM
GENE-KEISLER SALES's Avatar
0GENE-KEISLER SALES
Former Vendor
Default Keisler Engineering
check this out!
http://www.keislerauto.com/gm/transm...68-82_auto.asp
Old Mar 29, 2007 | 02:11 PM
White79's Avatar
White79
yeah the keisler is a good kit if your willing to spend the money....
Old Apr 1, 2007 | 07:45 AM
tomas35's Avatar
tomas35
5th Gear
Default Conversion
Wich one do you like best?
Old Apr 1, 2007 | 08:24 AM
Binnie77's Avatar
Binnie77
If you are referring to the TKO from Keisler, your decision should be based on the rear end ratio that you are running and the torque that your engine is putting out. If you have the original engine and transmission in your car, then your differential has 3:08 gears. Keisler will recommend the TKO - 500 for your setup. If you have modified your drive train or plan to in the future (ie) going to say 3:56 gears or higher then you need to consider the TKO-600. There is only a couple hundred bucks difference in the two. The TKO - 500 is good for 500 lbs of torque so that will look after most of us.
Oh and as far as which one you like best, you will LOVE either of them, I assure you! Just talk to Richard or Gene at Keisler and they will recommend the best one for your setup.
Old Apr 1, 2007 | 03:31 PM
tomas35's Avatar
tomas35
5th Gear
I think I'm going to install it.
Next thing is to convince my mechanic! A german dude that isn't convinced yet to help me to do the work.
Another question:
What can I install to make my brakes more powerful.
The car has the original brake installation but I installed BVP o-ring callipers and new shoes, but it´s not enough.
Greetings from Mallorca
Old Apr 1, 2007 | 03:52 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Another question:
http://www.corvettengineering.com/ You have E-Mail!
To '75 auto-manual conversion
