Shaky '79 Steering Column
Old Mar 29, 2007 | 05:32 PM
Mefixum's Avatar
Mefixum
Cruising
Default Shaky '79 Steering Column
I had a mechanic say my steering column fails inspection (Virginia) because when the steering wheel is pulled down it dips about a 1/4 inch. The column feels like something inside the tilt assembly may be loose. Is this slight dip normal for a 79 vette with T & T?
I've had the column disassembled down to the point where I did tighten and thread lock the 3 bolts inside the column near the bearings (past the tilt pivot point) if that makes sense.?
Also, I need an idea of how I replace the bearings. (Some fell out when I was tightening those 3 bolts…I did put the fallen bearing that I found back in. Man that was fun!
What do you think?
Thanks for the help!!!
Ken
Old Mar 29, 2007 | 06:43 PM
Durango_Boy's Avatar
Durango_Boy
I had a '77 with that same problem. My mechanic told me that inside there are a bunch of plastic rings and bearings. He said some of the plastic rings were cracked, and he'd have to tear into the column to replace them. I sold the car before I had a chance to fix it. Just thoughts.
Old Mar 29, 2007 | 08:05 PM
DeeVeeEight's Avatar
DeeVeeEight
I hate to admit to this, but I found a rebuilt column on ebay for under $300.00 My old column had the same problem. The rebuilt unit was well worth it, new keys & lock cylinder, turn signal mechanisms, bearings etc...
Old Mar 29, 2007 | 08:15 PM
Big2Bird's Avatar
Big2Bird
Download the Jim Shea papers. If you got the three screws, the tilt pawls would be next on my list to check.
To Shaky '79 Steering Column
