Side window adjustment
Old Mar 30, 2007 | 11:46 AM
Tonys96's Avatar
Tonys96
Default Side window adjustment
I recently replaced all the weatherstripping, my goal was to be able to drive through the carwash.
So who's adjusted the side windows and can give away any secrets. I have the manual and there is a procedure there, has anyone used it.
The drivers side window is set too far forward, I had to change the hinge bushings as well as weatherstripping. The window now hits the forward portion of the weatherstripping in the door and the metal channel on the windshield A pillar, stopping it from going all the way up.
Looks to me if I could move the glass back, all would fall into place.
Manual says that by removing the inner door panel and loosning the three bolts that hold the front vertical guide I should be able to just slide the entire window assembly rearward enough to get my front spacing correct, that sound correct ?
Old Mar 30, 2007 | 11:53 AM
HighHeat303's Avatar
HighHeat303
Yup thats how you do it. I've dont it but it has been awhile i remeber there being 2 tracks, the front and the rear, but maybe it is only one. Basically your just moving the window track, and the window has to stay on the track so if you move it back the window will go back as well. what year do you have? and how much did the weather stripping run you? I could use some new stuff too. thanks
Old Mar 30, 2007 | 12:57 PM
ajrothm's Avatar
ajrothm
I need to do this as well. My pass window is too far forward about 1/4". It actually hits the metal trim slightly. I just installed new wewather stripping also. Might mess with it this weekend.
Old Mar 30, 2007 | 01:01 PM
SIXFOOTER's Avatar
SIXFOOTER
Get a Sixpack, it takes some time to get it right. Works out better if all the window hardware is new, rollers mostly. I figure as long as I have to take it apart I only want to put it back together once.
Clean everything, replace the wear parts, reassemble and adjust. The procedure works pretty good
Old Mar 30, 2007 | 02:22 PM
427-390's Avatar
427-390
Go to Zip products home page and click on the section with the Tech articles. They just did an article on replacing weatherstripping on C3 doors. In the article, it shows what you need to do to adjust the door windows up/down/back & forth.
Good luck
Old Mar 31, 2007 | 09:57 AM
MN80Vette's Avatar
MN80Vette
Good luck
I went to the Zip site and tried to click on "Tech Articles
Featured Corvettes & More" but that text is not a link.
Is the ZIP web site broken, or am I trying to click in the wrong place?
Do you have the URL to the article you referenced?
Old Mar 31, 2007 | 10:15 AM
Tonys96's Avatar
Tonys96
Originally Posted by HighHeat303
... what year do you have? and how much did the weather stripping run you? I could use some new stuff too. thanks
This is on my '79
I bought the weatherstripping kit from Wilcox, great vendor and price. If I remember right 197.00.
Good quality and great service.
Old Mar 31, 2007 | 09:48 PM
Johnny_Johnson's Avatar
Johnny_Johnson
Try this:
http://www.corvettemagazine.com/2007...eplacement.asp
Later,
Johnny
Old Mar 31, 2007 | 09:56 PM
Big2Bird's Avatar
Big2Bird
I would like to add somone is finally making the right rubber. Most repops up untill now are harder rubber than the original soft latex. This causes many problems. The new Rik's catalogue shows the new, original style. Others will probably follow suit.
Old Apr 1, 2007 | 12:22 PM
MN80Vette's Avatar
MN80Vette
Originally Posted by Johnny_Johnson
That worked. Thanks!
To Side window adjustment
