What is this relay?
Old Mar 30, 2007 | 10:25 PM
Urban Cowboy's Avatar
Urban Cowboy
4th Gear
Default What is this relay?
Recently while rebuilding my 1970 coupe I found two relays under the jack stowage compartment tray. Due to water intrusion, I guess from the T-tops they both look like they were sitting at the bottom of a lake for several years. The rectangular relay has been reduced to about a third of its size and is just a block of rust. In the assembly manual it is identified on UPC UA6 sheet A3. According to the diagram the round relay is the flasher relay but the other is not identified. I suspect that this might be a relay for the alarm system? I would appreciate some assistance in the identity and if it is this relay is readily available. Thanks for all your help!
Old Mar 30, 2007 | 10:31 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
You already guessed correctly, those are the alarm components.
