alternator options?
Old Oct 14, 2001 | 12:55 PM
Jim 77's Avatar
Jim 77
Default alternator options?
Well the time has come... I need a new alternator.
Should I get a stock replacement?
I have a (previous owner) stereo that when cranked up all the way, or in other words, almost always, dims the lights...
I think someone said that an alternator from an 88 L98 camaro is higher amps and will fit my 77 L48/4 speed/power everything.
Will this work with existing wires/guages/brackets?
Thanks!
Jim
Old Oct 14, 2001 | 04:35 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: alternator options? (Jim 77)
Look at a rebuilt for an early C4 - they had higher amp. alternators.
Just make sure it has the same mounting as yours.
In most GM cars they used what is called a 10-SI alternator, they are a dime a dozen. My 1980 has a larger housing and I was told that it is called a 15-SI and is more rare.
You can also get 100 amp units from Summit racing, they are the 10-SI type.
Old Oct 14, 2001 | 05:27 PM
SteveG75's Avatar
SteveG75
Go to http://www.alternatorparts.com .
They have a lot of options ranging from upgrade kits to brand new alternators. I got a kit that upgraded my 42Amp to 80Amp.
Cost: $24.95 plus about 45 min of my time. They also have a kit for 105Amps for $30 or so if I remember correctly. That extra $100 or so left over will pay for a new intake manifold. :cool:
[Modified by SteveG75, 3:35 PM 10/14/2001]
To alternator options?
