Parking Brake handle removal
Old Mar 31, 2007 | 09:47 PM
IMA 66's Avatar
IMA 66
Default Parking Brake handle removal
How do i get the handle of the parking brake off so i can slip the new plastic slider piece over it? 1974 by the way
Old Mar 31, 2007 | 09:57 PM
1stC3Vette's Avatar
1stC3Vette
Cut a slit in the new slider and slip it over the handle carefully. This is the only way you can do it so that you can remove it if need be.
Good luck,
Dino
Old Mar 31, 2007 | 10:09 PM
IMA 66's Avatar
IMA 66
Thanks. Will it hold together good after it is slit?
Old Apr 1, 2007 | 12:21 PM
1stC3Vette's Avatar
1stC3Vette
Yes. The tracks will hold it in place just fine.
To Parking Brake handle removal
