problem with steeroids rack you should check
Old Apr 3, 2007 | 07:12 PM
tellcom2001's Avatar
tellcom2001
Default problem with steeroids rack you should check
i put a steeroids rack on my car a month ago. and today i put it on the lift to check everything. and on the passanger side the metal line was being hit by the big black plate and almost cut thru the line. so if you have this rack take 2 minutes to check it. i called steeroids today but they were closed. ill let you know what they say wensday night
Old Apr 3, 2007 | 09:54 PM
mrvette's Avatar
mrvette
I put my own rack install in some 6 years ago, before steeroids ever hit the market, they were still in testing....
at any rate, like I did, just bend the damn lines outta the freaking way...the position of them is not sacrosanct or summfin....
I even dinged the bottom of my truck 350 roller engine '89 4 bolt to get me an extra 1/2 inch clearance...big deal...
Old Apr 4, 2007 | 12:27 AM
MN80Vette's Avatar
MN80Vette
Do you have a picture of the metal line that hits whichever plate?
Old Apr 4, 2007 | 12:41 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i had to get two extra washers to use as shims to make the black mounting plate have the correct spacing....is this where yours was hitting....
[IMG][/IMG]
Old Apr 4, 2007 | 08:59 AM
mrvette's Avatar
mrvette
[IMG][/IMG]
Gad, that looks terrible...like that plate is about 1/8 inch thick, IMO that's not enough, and too boot it looks bent up top, and as if the tie rod loading in a turn? bent it...
summfin ain't right there....
Old Apr 4, 2007 | 09:16 AM
bobs77vet's Avatar
bobs77vet
the bracket does have a "designed" bend in almost like a skid plate. my system works fine, it turned out the suppliers hoses were just a wee bit too long in that dimension
Old Apr 4, 2007 | 03:41 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
That all looks like a flimsey design. If i ever do this mod i will make the brackets myself like you did. Those spherical joints have no protection against the elements and will probably wear/rust out in a year.
I wonder who is going to be the frist one to wreck their car because of a failure of something on this design?
Old Apr 4, 2007 | 07:32 PM
tellcom2001
update spoke to steeroids maker. and they informed me they had about 50 to 60 of these clocked wrong. so they are sending a new one out thursday. atleast they admit when there is a problem and make it right<a href="http://photobucket.com" target="_blank"><img src="http://i126.photobucket.com/albums/p119/tellcom2001/steeroidsbentline.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>. will post pic of the line that got wacked in a few minutIMG]http://i126.photobucket.com/albums/p119/tellcom2001/steeroidsbentline.jpg[/IMG]es
Old Apr 4, 2007 | 07:40 PM
tellcom2001
cant get the pic to upload. how do you get them from photobucket????
Old Apr 4, 2007 | 07:53 PM
bobs77vet's Avatar
bobs77vet
just copy the "IMG...." and then click onthe yellow box icon (above) and paste in the box that appears...it has to say "IMG"
Old Apr 4, 2007 | 08:31 PM
Binnie77's Avatar
Binnie77
Thanks for the 'heads up'. I will check mine tomorrow.
Old Apr 4, 2007 | 08:38 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
See if this works.
Old Apr 4, 2007 | 08:40 PM
Eddie 70's Avatar
Eddie 70
After seeing this pic, I need to get out there and take a look at mine and see how close the line is. I don't remember it being close but that has been a while. I guess checking it over closely is never a problem, it is called PM (preventative maintenance).
Old Apr 4, 2007 | 09:19 PM
Cookwithvette's Avatar
Cookwithvette
Thanks for the heads up... I'll be sure to check.
Old Apr 4, 2007 | 09:22 PM
bobs77vet's Avatar
bobs77vet
that looks like exactly where mine was hitting......it was obvious to me when I installed it so i didn't have any problems.
Old Apr 5, 2007 | 09:26 PM
tellcom2001
thanks eddie 70 for getting my pic on. save the wave
Old Apr 5, 2007 | 10:29 PM
MN80Vette's Avatar
MN80Vette
Default No problem with mine!
I think the design is pretty good for the intended use. You can't judge a design by looking at just one corner of one piece of a complete system. There is no fore-aft force on that plate, only lateral force. The plate goes all the way across and is not flat. If the design was weak and prone to failure, I am sure the word would be out by now.
The spherical joints are plated. They are no more susceptable to rust than an plated bolt.
As far as the metal tubing contact problem is concerned, they obviously resolved the problem some time before I bought mine more than a year ago. The metal lines are nowheres near anything that could rub through.
I still say Steeroids was one of the best upgrades I made on my car, second behind a GM 350 HO Deluxe crate engine and ahead of a front mono-leaf spring.
To problem with steeroids rack you should check
Old Apr 6, 2007 | 02:03 PM
tellcom2001
i love the steeroids rack . it was clocked wrong by the mfg. and there sending a new one
Old Apr 6, 2007 | 02:31 PM
bobs77vet's Avatar
bobs77vet
i must have been the first one....since they had no idea why it was hitting, i even was talking to the engineer who designed it
Old May 9, 2007 | 10:15 AM
Binnie77's Avatar
Binnie77
Just realized I have the same problem
