Lexan windows
Old Oct 14, 2001 | 11:21 PM
xfactor974's Avatar
xfactor974
Default Lexan windows
Where can I find some nice lexan windows for the vette?
Old Oct 15, 2001 | 10:24 AM
gerry72's Avatar
gerry72
Default Re: Lexan windows (xfactor974)
Pre-sized to fit? Nowhere. Lexan is a polycarbonate that you can easily trim to fit your application. Hope you're not considering these plastic windows for you street car. Very bad idea.
Old Oct 15, 2001 | 10:29 AM
Bifkin's Avatar
Bifkin
Default Re: Lexan windows (gerry72)
Why is it bad for the street?
Old Oct 15, 2001 | 03:47 PM
norvalwilhelm's Avatar
norvalwilhelm
Lexan will not break. It is used around hockey rinks as glass. You can take a piece and hit it on a chunk of steel and it will not break. It does scratch and will turn yellow if exposed to sun. It can be used on side and back windows but not a windshield. Race cars run plexiglass. This stuff does break so the holes must be burnt in with a hot poker. Lexan is bought in sheets and easily cuts with a band saw into any shape. It can also be bent into permanent shapes with heat from a hot air blower
Old Oct 15, 2001 | 04:10 PM
Edzred72's Avatar
Edzred72
Default Re: Lexan windows (norvalwilhelm)
Over a period of time,it will also will turn permanently clowdy from washing. Not to mention how the windshield wipers will scratch the H--- out of it! :smash:
To Lexan windows
