oil cooler
Old Apr 4, 2007 | 11:30 AM
81cali's Avatar
81cali
Default oil cooler
How and where do you connect an oil cooler? My son has one laying around that he's not using and I thought maybe I can adapt it to work on the vette. My oil temp goes from 220 to above 250.
Old Apr 4, 2007 | 11:34 AM
Durango_Boy's Avatar
Durango_Boy
You will want an oil filter sandwich adapter.
It goes between the filter and the block and has two fitting bores. Install nipples, and run a line to and from a cooler.
Old Apr 4, 2007 | 04:20 PM
81cali's Avatar
81cali
Thanks Matt. Is this something I can easily acquire from a local parts store?
Old Apr 4, 2007 | 04:23 PM
Durango_Boy
Maybe not...I got mine from Summit for $35. I can't find a link with a picture but if you have a catalog of theirs I believe it's in it. also check Jegs and JCW.
Old Apr 4, 2007 | 04:26 PM
81cali's Avatar
81cali
OK. I have summit and jegs catalogs, is that what they're called - oil filter sandwich adaptor?
Old Apr 4, 2007 | 04:27 PM
Durango_Boy
Yep. You'll see it...very easy to tell what it is.
Old Apr 4, 2007 | 04:29 PM
81cali's Avatar
81cali
One last thing, where did you bolt yours to? (do you have a pic)
Old Apr 4, 2007 | 04:31 PM
Big2Bird's Avatar
Big2Bird
1 unsolicited opinion. Breaking a hose and losing oil pressure would scare me alot more than 250* oil temp. No charge for that.
Old Apr 4, 2007 | 04:33 PM
81cali's Avatar
81cali
Are you saying that it's normal to cruise at 250 oil temp?
Old Apr 4, 2007 | 04:36 PM
Durango_Boy
Yep, this is what it looks like in place before the filter is threaded on.
I have not mounted the cooler itself yet but I will likely place it in front of the radiator on the driver's side lower corner. Something small.
Old Apr 4, 2007 | 04:45 PM
Big2Bird's Avatar
Big2Bird
Yep
Old Apr 5, 2007 | 08:21 AM
BerniesVette's Avatar
BerniesVette
I installed a B & M stack type cooler on my 92 with a remote oil filter using braided steel lines. It really cools the oil below 200. Too much in the winter mos. I mounted my cooler behind the fans and it still does a great job.
Bernie
Old Apr 5, 2007 | 09:56 AM
Bangkok Dean's Avatar
Bangkok Dean
Mine works good.
Old Apr 5, 2007 | 12:40 PM
GUSTO14's Avatar
GUSTO14
I've always been of the opinion that oil coolers can be "cool" on a street car and will certainly give it the race car look. They will usually do an adequate job of lowering your oil temp, some better than others, and will very often add additional capacity to your oiling system without having to change oil pans.
If you do add a cooler, consideration should be given to adding a bypass thermostat to the system, especially for those in colder climates as you will want the oil to come up to operating temp as quickly as possible. Without a thermostat, in colder climates, some will not reach an adequate operating temp at all.
As you might have guessed, I like external oil coolers, but one option you might consider if you just want to lower the oil temp is try switching to a full synthetic oil, if you have not already. If you are using a synthetic, 250 degrees is not too high at all.
Good luck... GUSTO
Old Apr 5, 2007 | 02:09 PM
a1sensei's Avatar
a1sensei
250 is not too high, although it is above where mine runs unless I'm cruising at over 100mph in hot weather. I use a 180 degree thermostat, redline water wetter without antifreeze (Florida is great) and full synthetic oil, so my car may just run cooler.
But my real point is this: if your oil is hotter than it should be, find the reason and correct it! You're car was designed to run at the correct temp without an external oil cooler. Unless you have modified the engine in some way that causes high oil temps, the solution is not an oil cooler, it is finding the problem and fixing it . God bless, Sensei
Old Apr 5, 2007 | 02:54 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Oil cooler cools oil
To oil cooler
