bangs in gear
Old Apr 4, 2007 | 10:42 PM
wiseman79's Avatar
wiseman79
Default bangs in gear
Every automatic vette I've been in bangs going into gear, how can I resolve without putting in a sloppy convertor?
Old Apr 4, 2007 | 10:48 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Maybe you could be more specific. I have 3 auto tran's
Vette's, Banging?
Old Apr 4, 2007 | 11:51 PM
wiseman79's Avatar
wiseman79
Sorry thought this was a common problem since I've seen it in a few cars. When I go into gear there's a bang coming from the rear as it goes into gear.
Old Apr 5, 2007 | 12:19 AM
SIXFOOTER's Avatar
SIXFOOTER
you get a Bang because there may be a little slop in the drive line because of high milage. These things are not cadillacs, they have a crisper shift than most cars which is a desireable thing in a sports car
Old Apr 5, 2007 | 09:13 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
An idle that is too high will also cause the hard shift into gear.
Old Apr 5, 2007 | 10:46 AM
TimAT's Avatar
TimAT
C4's had a thing with shifting from R-to-D. The halfshafts would make a pinging sound when everything took up the slack. We fixed it by shooting spray undercoat inside the shafts.
Bottom line- with any wear, there are lots of joints that have to take up slack on our C3's. High idle, wear, etc., will make a bang changing directions.
Old Apr 5, 2007 | 10:51 AM
Maymyvetteliveforevr's Avatar
To a certain point you will always get some sort of "Bang" in a C3. Possible causes of excessive Bang are as follows:
Shift kit added to transmission.
Worn U-joint.
Idle to high.
Play in drivetrain.
Maybe even depending on stall speed in converter.
Please feel free to add to list.
To bangs in gear
