View Poll Results: Off with hi head(s)?
Pull'em stupid. Your there
60.00%
Change the seals/good enough
30.00%
Leave it alone. It runs fine
5.00%
Not enough info
5.00%
Voters: 20. You may not vote on this poll
Off with his head(s)?
Old Apr 5, 2007 | 09:38 AM
Big2Bird's Avatar
Big2Bird
Default Off with his head(s)?
Okay, Read the post . http://forums.corvetteforum.com/show....php?t=1668939
Vote for your choice. 58,000 miles. Slight puff on start -up. Intake and exhaust manifods are already off.
Old Apr 5, 2007 | 09:57 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
nothing wrong with the engine, why pull the heads ?
replace valve seals and timing chain set as well as the oil pump drive shaft - does the one with the metal sleeve fit the stock pump ?? Probably better than the plastic junk....
Old Apr 5, 2007 | 09:59 AM
SIXFOOTER's Avatar
SIXFOOTER
OK, so I didn't read the other thread, but for a puff on startup I am cheap so I would just do the seals and see what happens
Old Apr 5, 2007 | 10:25 AM
TimAT's Avatar
TimAT
Throw a compression test on the thing before you do anything else. I'd bet they're all decent. Be careful-- whileimhereitis.
You've got the pan off, the manifolds off, pull the heads, and "gee, I'm here, I may as well toss a set of rings in, Oh, darn, the cylinders look worn, I better measure, OOPS, I need to bore, Well I've got the crank out, I'll check it, I need a crank...."
You get the idea.
Old Apr 5, 2007 | 10:29 AM
Big2Bird's Avatar
Big2Bird
You get the idea.
No arguement here. I am famous for this. The older I get, the more I lean toward "If it's not broken".............. We are changing the rear main seal while the pan is off. That's a no brainer for me.
Old Apr 5, 2007 | 11:00 AM
jackson's Avatar
jackson
58K OE 72 BBC runs OK w/ slight puff on startup ... I&E manifolds already off.
Pull heads ... clean em ... check guide-stem wear.
If guide-stem OK ... hand-lap valves w/ compound ... replace seals ... replace 35 year old springs.
To Off with his head(s)?
