BB Timing chains
Old Apr 5, 2007 | 12:52 AM
Big2Bird's Avatar
Big2Bird
Default BB Timing chains
Last Saturday I went to another CF members house to help install a manifold and rebuilt Dizzy. As soon as I looked under the hood at that BB 454, I was back in High School working at a service station.
We had an account, fleet of BB 1 Ton trucks we serviced. I remembered changing an exhaust manifold, or timing chain at least once a month in 1 of their trucks.
I shared this story with John, and we decided while the manifold was off, why not take a look see. The valley has a nice 1 1/2" hole in the front, right behind the cam sprocket.
Here is what we found.
Now one of the Generals not so bright ideas was to make the cam sprocket out of aluminum, with nylon teeth, for a quieter engine. STUPID. This engine has 58,000 documented original miles. The slack in the timing chain was so bad, I almost slipped it off the cam sprocket.
Some of you have PM'd me concerning timing difficulties with your BB motors. If you have this original set-up in this condition, your dizzy will never be able to perform it's function.
Old Apr 5, 2007 | 12:56 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Thank you BigBird for the information that may help others. Oh one thing to add True Double Roller.
Old Apr 5, 2007 | 01:03 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Great pics....better drop the pan and clean out the oil pump pickup. Guess where all that plastic is???
JIM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Great info Big!!! Pontiac was another one notorious for shearing off teeth on the timing gears because of plastic construction.
Dep
Old Apr 5, 2007 | 01:04 AM
Ironcross's Avatar
Ironcross
That type of timimg gear is standard equipment on all Chevrolet V8`s. Just change it to one from a truck or any other steel gear setup and you will be fine. But remove the broken nylon pieces from the oil pan too.... .
Old Apr 5, 2007 | 01:09 AM
Big2Bird's Avatar
Big2Bird
Pan is off. We are done going backwards. Tomarrow the new chain goes in. Parts per Iron Cross instructions.
I just wish it was a pick-up, not a Vette. They must have used shoe horns to get that thing in there.
Old Apr 5, 2007 | 01:14 AM
DJ Dep's Avatar
DJ Dep
Of course, it you want the "turbine sound", you can always go with a full gear drive setup
http://www.milodon.net/geardrives/pg44.htm
Old Apr 5, 2007 | 01:22 AM
Big2Bird's Avatar
Big2Bird
It's a nice, pretty unmolested #'s matching 72 454. He wants to retain the stock appearance.
Next decision up for grabs. The valves are pretty grungy for the milage. I know the valve seals are gone/turned to stone. The engine runs strong, and it does not smoke/use oil. Just a puff on start up.
I am tempted to do just the seals on the car, not a valve job. I am willing to bet the guides are fine. Opinions.(I know there is no shortage of em).
Ironcross's Avatar
Ironcross
Way too much overkill. Great for supercharged gas/fuel racing engines that also require a fuel pump drive on the cam gear. I personally prefer the Donovan racing drive for my Chryslers. But why not, I run a Donovan..... Not good for street. ... ......
Old Apr 5, 2007 | 04:01 AM
Clue's Avatar
Clue
Will those nylon teeth also be on my 1974 LS4?
Old Apr 5, 2007 | 08:20 AM
coinwasher's Avatar
coinwasher
I just put valve seals on a buddy's 58,000 mile '72 small block that was doing the puff on startup thing. The motor was VERY clean inside and half of the valve seals had turned to stone.
I wiggled each valve stem side to side when the spring was off and found many worn stems. The small block needs a valve job.
IF there is some money available on this project and If you are telling us that the manifolds are off then why not pull the intake and slip those heads off? Also If I had the oil pan still off I would consider a fresh oil pump and get that brittle plastic sleeve replaced on the oil pump shaft.
Old Apr 5, 2007 | 09:07 AM
Big2Bird's Avatar
Big2Bird
Yes. All Chevy BB came with these.
Old Apr 5, 2007 | 09:09 AM
Big2Bird's Avatar
Big2Bird
That has been suggested. It is not my car, and the owner will make that determination. I will look into the pump sleeve. Thanks.We are changing the rear seal today.
Old Apr 5, 2007 | 09:51 AM
DJ Dep's Avatar
DJ Dep
It's old school for sure. And yes, I've heared them used on the street. They actually make a "silent" version without the high-pitched whine. The gear drive isn't really essential for good operation...but coolness factor is way high. Like listening to a jet turbine on a helicopter
Dep
Old Apr 5, 2007 | 10:14 AM
TimAT's Avatar
TimAT
If the guides are really worn, seals won't help for long. A good set of Perfect Circle seals on any Chevy will help. To really check the guides, the heads need to be on the bench, springs off, and lift the valve off the seat. See how much slop there is. On the seat, or too far off the seat, ( I forget what the actual spec is), and you get phony readings. The valve has to be in it's normal range of travel, but off the seat to really know how loose the guides are.
GM used those )(*#&$^ nylon covered gears in everything I can think of. I've taken the chain off with both gears still installed. On my stuff, or anything that had any kind of performance, I always go back with a double row roller chain, Cloyes, TRW, even GM has them.
Old Apr 5, 2007 | 10:22 AM
shafrs3's Avatar
shafrs3
Cloyes True Roller.
Old Apr 5, 2007 | 10:25 AM
Big2Bird's Avatar
Big2Bird
Originally Posted by shafrs3
Cloyes True Roller.
I believe the speed shop sold him a set by Comp Cams. Good/bad/ugly?
I know what to do. Am just not hip on quality on some items.
To BB Timing chains
Old Apr 5, 2007 | 10:30 AM
DJ Dep's Avatar
DJ Dep
Probably good, as long as they are all metal and no plastic
Old Apr 5, 2007 | 10:32 AM
TimAT's Avatar
TimAT
I just looked at Comp's catalog. They show both a double roller chain AND a Morse-type. Which one did the speed shop sell him? Personally, I'd go with the double roller, but that's just me. I don't think there is anything wrong with the Morse chain and steel gears.
Old Apr 5, 2007 | 10:35 AM
Big2Bird's Avatar
Big2Bird
John??????????????????????? Part #?
