I have a SB. I went with the Slalom (sp?) kit from VB&P with the front poly rebuild kit. Thanks to this post, I realized this morning that my front end rebuild kit came with the Poly shock mounts (VB&P#31001) so I threw away the 3rd washer and changed them out.
I chose the stiffer springs because I asked guys on the forum about a month ago for advise. Two guys replied that went with the softer springs and both said they should have gone stiffer. Your best bet is the VB&P Touring Plus or the Slalom depending on what kind of ride you want. I won't have input on my ride because I'm getting ready to pull the body off. Let me know if you plan to pull the A Arms and change the bushings. I can let you know the best way to do it....gp
