Dizzy gear
Old Apr 6, 2007 | 12:22 PM
Big2Bird's Avatar
Big2Bird
Default Dizzy gear
Okay engine gerus. I am rebuilding a dizzy for a CF member. It's a tach drive for a BB. He has a Comp Cam. He is on the fence as to witch dizzy gear to use. What say you?
Old Apr 6, 2007 | 12:25 PM
Gordonm's Avatar
Gordonm
If it is a non roller Comp Cam he can use the standard gear. I have had the same gear on mine with 3 different solid Comp Cams. Roller cams might need a different gear depending on the cam makeup.
Old Apr 6, 2007 | 12:26 PM
S489's Avatar
S489
i'd call comp with cam # and use their recommendation . . .
Old Apr 7, 2007 | 12:36 AM
Big2Bird's Avatar
Big2Bird
TTT. It's dizzy gear day.
Old Apr 7, 2007 | 09:11 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
The composite gear is the way to go if you want NO issues ever. Big bucks though.
Old Apr 9, 2007 | 11:18 PM
724544SPD's Avatar
724544SPD
I called the Comp Cam tech hotline today. Theyadvised that the stock gear would be OK.
To Dizzy gear
