Body mount/frame rot #4 (pics)
Old Apr 7, 2007 | 07:17 PM
CorvetteDave01's Avatar
CorvetteDave01
Default Body mount/frame rot #4 (pics)
I just got done getting the right side #4 body mount out, I am sure the left will be similar. I have some new poly body mounts and the new cages for the #4 mounts, but the frame mount is rusted, needs replaced/repaired. Questions...
1. How do the body grommets go in exactly? Small radius of the grommet out or in?
2. How big is this hole supposed to be in the frame standoff? It obviously is rusted out pretty bad.
Any help would be appreciated, so thanks.
Old Apr 7, 2007 | 07:38 PM
LYLE's Avatar
LYLE
I made some plates out of 1/8 material and just cut out the top of the rusted area and welded in the new plate. I am guessing but I think the hole was 1 and 3/16 inch. The small end goes through the mount.
Old Apr 7, 2007 | 08:05 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I'm in the same boat. I pulled one side off and it just crumbled. I'm grinding the center out and welding in a washer with a enlarged hole.
I just measured a poly bushing and it's 1 1/8".
Old Apr 7, 2007 | 10:20 PM
CorvetteDave01
OK, 1 bushing per mount then, was thinking 2, top and bottom for some reason. Yeah, I have some 1/8" steel, guess I'll do the same and weld/repair it. Thanks a lot for the hole size, that helps a lot. I'll post some more pics after I repair it.
Old Apr 8, 2007 | 10:46 AM
LYLE's Avatar
LYLE
Their is a pair of bushings that go on each mount using original rubber mounts. They go up small end from the bottom on #2 and #3 down small end from the top on #1 and #4.
To Body mount/frame rot #4 (pics)
