Which spark plugs to use?
Old Apr 8, 2007 | 01:59 AM
sperkins's Avatar
sperkins
Default Which spark plugs to use?
Picked up the subject from a thread a couple of months ago. I'm trying to find the correct plug to use on my 327. I do have the TRW pop up pistons (10.3:1) and I'm running 64cc Edelbrock Performer RPM heads. I also have Hooker side mount headers so I need a plug that is as short as possible. I'm not a big fan of Accel and I read in the quotes below about the NGK's. My only question is are the NGK's correct for my application (Summit says I need an "S" heat range plug) and are they shorter than stock?
Thanks in advance.
Scott
Sorry - I meant o add I'm running a stock HEI distributor.
Originally Posted by Mark_Milner
The original plug for Corvette 327s through '68 was the AC 44. In 1969, it was the R44. The 44 series is not available anymore, but no matter as it was really a bit too cold for normal driving. The 45 series is better.
There is no real performance difference in the 45 or R45. The R is for resistor plugs which help reduce ignition noise in radios. The R45S has an extended tip which helps keep it cleaner from fouling and so it runs a bit better. However, if you have high domed pistons or the heads have been shaved, you could hit. You need to install the plugs, turn the engine over, and then check the plugs if you have any performance work done on the engine.
If you are running the R43S, you'd better be doing hot laps most of the day, because it is far too cold for the street.
Originally Posted by paul67
I agree with Joe. The NGK B-4 is the same heat range as the AC 45 (hard to find) and is non-resistor and non-extended tip.
Old Apr 8, 2007 | 02:10 AM
SEVNT6's Avatar
SEVNT6
I can't tell you if that's the right plug. I can tell you that NGK plugs are the best I've ever used in my Vette...............
Old Apr 8, 2007 | 08:50 AM
Durango_Boy's Avatar
Durango_Boy
Ditto...I LOVE NGK. They are the best I have used too.
Old Apr 8, 2007 | 09:50 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Bosch Platinum # 4236 is a terrific spark plug. It is a 45 heat range. I use it in my L79 65. and it runs better than any plug I have used in 35 years on this car. I do not disagree with NGK as others have mentioned. They are great plugs too.
Old Apr 8, 2007 | 11:20 AM
Roughrider's Avatar
Roughrider
I run AC Rapid Fires in my car and think they're great. That being said, my local speed shop I deal with likes NGK the best.
To Which spark plugs to use?
