What about this EFI engine?
Old Apr 8, 2007 | 08:44 AM
jacobsed's Avatar
jacobsed
Default What about this EFI engine?
Has anyone put one of these in a C3? Will it fit under a stock 79 hood?
http://www.edelbrock.com/automotive_..._efi_440.shtml
Old Apr 8, 2007 | 10:20 AM
Rotonda's Avatar
Rotonda
Barely! I had an Edelbrock Pro-Flo RPM on my 77 several years ago. The only air cleaner that would fit was one of those triangular downflow types with a foam filter element. I had to grind off 1/4 to 1/2 inch from the bottom to get more clearance, and you will also probably have to sacrifice your hood insulation pad.
Old Apr 8, 2007 | 10:37 AM
fl_rider's Avatar
fl_rider
Default Looks nice !!
I am sorry but I cant tell you if it will fit.
Chris B
Old Apr 8, 2007 | 11:05 AM
Roughrider's Avatar
Roughrider
I have a car in the rebuild shop right now with a new crate engine and the Edelbrock Pro-Flo RPM EFI. Not a Vette...an Avanti. Still it has limited hood clearance.
While my car isn't done yet, it looks like a stock type air cleaner won't clear the hood. I'm not yet sure a drop base air cleaner will work. My other two options are the Holley Hi Tek air cleaner, or go to a supercharger carburetor bonnet with a remote air filter. I won't know yet for a couple of weeks.
Wish I could give you a better answer. I know it can be done...just what the exact answer for you is may take some experimentation.
Old Apr 8, 2007 | 11:16 AM
mooneyd's Avatar
mooneyd
Do you know what the price is? Did not see one on the site. I like that set up alot. I'm looking into an engine for my '82.
Dave
Old Apr 8, 2007 | 11:23 AM
jacobsed's Avatar
jacobsed
First google search pulled up ~9K at scroggin dickey
http://www.sdparts.com/catalog/crate...ateEngine.aspx
To What about this EFI engine?
