I'm pretty sure this is the route I'm going. TH400, stock converter, and a mild upgrade to an L48. If anyone has made this change, how drastic of an improvement in acceleration (highway windup is irrelevent)? With stock 3:08s, my F350 will probably kill me in acceleration.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
You'll see a lot of difference from red light to red light. I like low gears...about the most go.. you can get for the money.
I have 3:55's(or 3:50's?) with a 700r4, which with its first gear is about the limit.
Larry
You'll notice alot more acceleration but also alot more noise, higher fuel consumption, heat but again better off the line acceleration.
Your top end and highway cruising will suck.
You really need the 700R instead.
I made that change ten years ago and with the 355 averaged 17 mpg commuting 400 miles weekly. As posted the highway cruise sucks,taching 3000 at 65 mph. I stay closer to 60 anyway due to the 55 mph speed limit,plus the "hotrod" look my car has draws a lot of Police attention anyway.
For what it's worth I ran a Comp 268H cam with my 355 and it was a fairly spunky combination for a 355.(At the time also was running a B&M th350/2000 Holeshot converter,which isn't much stronger off the line than a stock converter)
Changing gearing does not really make a car faster once it is moving. Because you still have the same motor. My 4 speed 2.73 rear end equiped Camero is a hot rod once it is moving. Once your moving and you have your petal to the metal - it is all motor TQ. My Vette in OD is like 2.6 something gearing and when I floor it it goes.
I changed from 3.70 to 3.08. With my 4 speed manual cruising at 85-90 the engine was tacking 4,000 and for long trips it was too much fuel and heat now it is still good light to light and decent on the high ways.
Over here if your not going 85 cement trucks pass you up.
Changing from 3.08 to 3.73 gears in my car lowered my quarter mile times by half a second.
Like gkull said though, gearing is most critical for standing start acceleration. From a rolling start you might be able to downshift to low gear with 3.08 rear, while with 3.73 gears you might only get down to second.
3.73's are great for all-around fun. Yes, the mileage is worse, and hiway cruising is just OK, but for a good launch and great middle speed response, they're hard to beat on a street car. Gear multiplication is one of the easiest performance upgrades there is, and if you ad an OD trans, you get the best of both worlds.
I ran them in my old '64 GTO with a 12 bolt and a THM 400 auto. Good for 12.8 on cheater slicks, and my GF drove it to college during the week. Lots of fun!
My 79 came with 3.55 gearing. IMO without an OD tranny it has good exceleration and exceptable rpm going down the road. I have a 4.11 in my Vette and it would drive me nuts without an OD tranny. In fact some times even wish that I had one more gear to get down to a 2.40 overall gearing.
Followup question, my 4 speed manual car had a 3.08 rear end put in it somewhere in its life. I actually like it on the highway, where I do most of my driving.
But is there any lower 1st gears ratios available for the 4 speed, to increase my off line acceleration?
Don't see why not (been a while since I did a T-10), but it would be pricey since you also need the cluster gear to match the new first gear. With the money you spend you could be half way to a modern OD trans.
