Console removal
Old Apr 9, 2007 | 07:50 AM
1996Z15's Avatar
1996Z15
Default Console removal
I started to remove the interior of my '69 so I could replace the carpet and replace the heater core while I was at it. I have run into a slight snag with the console removal. My car is a non-AC car and I need to remove the little ***** for the vents that are on the console. I think they are secured by some very small allen screws; similar to the one that holds the wiper over ride **** on.
I tried Home Depot for the small Allen key set but the closest I could get was a set that had a 1/16 wrench and then it went to a .050" wrench; one was too big, the other too small.
Does anyone know the correct size for this allen screw and where can I find such a small set?
Thanks,
Old Apr 9, 2007 | 02:49 PM
palamesa's Avatar
palamesa
McMaster-Carr would have the Allen set. Probably your local Sears too. Don't know the screw size.
Old Apr 9, 2007 | 04:15 PM
1996Z15's Avatar
1996Z15
Yea, that's the big question; what size allen wrench does that screw accept? I have a set of allen wrenchs and bought a set yesterday that had smaller sizes but, still don't have the right wrench.
I can't beleive that nobody on the site has removed a console or installed a new wiper override switch ****. They would need this same size wrench to do this.
Old Apr 9, 2007 | 04:50 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I just went out and checked on my 69 and it uses the 1/16th in allen wrench. If you push the **** all the way foreward the allen wrench will be parallel with the console face when it is in the head of the bolt. Also a ball end allen wrench is easier to get into the screw. GL
Old Apr 9, 2007 | 05:14 PM
1996Z15's Avatar
1996Z15
Thank you very much; now I can continue with my project.
To Console removal
