Casting numbers for 1970 LT1 heads?
Old Apr 9, 2007 | 03:23 AM
L Holmes's Avatar
L Holmes
Default Casting numbers for 1970 LT1 heads?
What are the correct casting numbers for the 1970 LT1 heads?
Thanks.
Old Apr 9, 2007 | 07:41 AM
HP Hunter's Avatar
HP Hunter
Default LT-1 Cylinder HEads ID
Thanks.
The correct part number from Chevy is 3927186 but are more commonly referred to as 186's.
On the LT-1 they used 2.020 intake valves, 1.600 exhaust valves, 7/16 x 3/8 screw in studs, 5/16 flat guide plates, and 1.250 single springs. They were available on other engines also but this is how the LT-1's were assembled.
Harry P. Hunter
Old Apr 9, 2007 | 09:15 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Harry P. Hunter
Correct for 69 and 79 370 hp engines! Got a magnafluxed set sitting in the garage if you need some. I think the 041 was used also in 1970.
To Casting numbers for 1970 LT1 heads?
