Brake job UPDATE
Thanks for all the help and info on the brakes. I posted a little while ago about my new Rear Calipers not bolting up. Turns out you guys were right about the front Rotors being on the rear. I ended up getting the package from VB&P for All Rotors and pads + I added the Front Calipers as well. Everything bolted up perfectly. I couldnt be happier with these products and service. This is the first time I started to install or remove something and had no snags. All I have to do now is hook up the rear line to the Pvalve and bleed the system. Everything in my brake system is brand new and upgraded. I should have no problems later. On to the rear suspension, drivetrain, and TAs.
Thanks again
Josh
